Airsoft bb's to balance tires..... - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Airsoft bb's to balance tires.....
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-14-2013, 08:49 PM   #16
GregStephens2
Thanks for moving this to the correct forum.
Not sure if this will help you guys or not but.......
I had and the shop I frequent had been rotating my tsl SX's front to back and keeping the rotation the same.
For what ever reason I had always though that bias tires had to be kept on the passenger or drivers side so the rotation was not reversed.
I ran out today to a buddies garage to use his set up to rotate tires and dick around with the jeep. He suggested I rotate them in the normal X pattern.
Which I did as I trust him, and my SW tick is gone and the tires are riding glass smooth.
The only thing I can come up with is the outer lugs had been worn more to the rear of the lug and some how this was creating a lateral shimmer which was F'ing with the tires.
This may be a known issue for some of you so please take it easy on me.
I was honestly amazed that simply reversing the rotation would fix the tick in the SW and the weirdness above 75 mph so I am stoked.
Swampers sound nice at 80! Especially when they are riding like BFG radials.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 03:01 AM   #17
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Seeing is believing
I use steel BB's in all of my vehicles and have for years. I haul cars for a living an I couldn't keep wheel weights on my trailer tires as they would just disappear and the flat spots caused by tight turns would negate any traditional static wheel weights any way, they run smooth and quiet and wear evenly.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote Quick reply to this message
