Air pressure-chalk test done-results - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Air pressure-chalk test done-results
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-14-2006, 04:35 AM   #1
mic6
Guys it is so strange.
I did the chalk test yesterday and the result is that I have to run 22psi in my 32x11.5 BFG Mudders so that they wear even. The thing is that the ride is much better on the street too at 22psi. I started the test at 30psi going down and ending up to 22psi. I have the 4-cyl with no heavy aftermarket parts so I understand my rig is light. But isn't 22psi too low for street and highway driving?
Any comments are welcome
Thanks, Mike
sorry, sorry I just realised I posted to the wrong forum
mic6 is offline   Reply With Quote
Unread 02-14-2006, 06:52 AM   #2
Jeepin' Rock Cl
That sounds a touch low, but not by a whole lot. If the ride is better and the tires wear better and the gas mileage isn't affected much, stick with it!
Jeepin' Rock Cl is offline   Reply With Quote
Unread 02-14-2006, 07:00 AM   #3
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
That does sound low, especially for that tire size... but it could be that you need to go that low because of the lighter weight of your rig. I'd be worried about the tires overheating & causing a blow out.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Unread 02-14-2006, 07:01 AM   #4
RockRunner85
I run 26 psi in mine. I tend to take corners harder so it wears evenly. Otherwise if I followed the chalk test exactly the would wear more on the edges. I would go with 24-25 psi and see what happens.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline   Reply With Quote
Unread 02-14-2006, 08:58 AM   #5
PSUSahara
I got 28 in mine.
2000 Sahara- RE 2" BB, JKS 1.25" BL/1"MML, 32" Kuhmo Venture MT's, XCB front bumper, Banks exhaust, 62MM TB, Flush LED's, other misc stuff
[B]Black Jeep Club #85[/B]
PSUSahara is offline   Reply With Quote
Unread 02-14-2006, 10:06 AM   #6
rock dawg
I've run 3 different sets of tires on mine and the chalk test netted different pressures for each set.
I wound up running 26psi on all of them though.
02 TJ 35" Toyo's locked both ends, winch, lift, blah blah...
rock dawg is offline   Reply With Quote
Unread 02-14-2006, 10:55 AM   #7
txjeepn
I have a 4cyl also and I run about 20 psi in my 33" dunlop mud rovers on my daily driver. So 22 psi does not sound off to me.
txjeepn is offline   Reply With Quote
Unread 02-14-2006, 11:04 AM   #8
Rocky529
Jeep
Rocky529's Avatar
The 4 cylinder engine is a lighter engine, therefore the cause of less psi. As long as you are making a full print on the ground, I wouldn't worry about it.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 02-14-2006, 11:29 AM   #9
de6w6it
I have 32x11.5 bfg mt's, and I had been running at 25 psi, but the edge lugs were wearing a little more then the middle lugs, so I upped it to about 26.5 psi, where I am at now. I have the 4 angry squirrels also, but I do have some extra skids, bumpers, and a whole lotta tools and a sub box adding some extra weight.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:http://www.yotatech.com/f191/de6w6it...-lemon-190657/
de6w6it is offline   Reply With Quote
Unread 02-14-2006, 01:01 PM   #10
BigWaylon
tubework is cool...
BigWaylon's Avatar
Thanks, Mike
I'd be curious to see how the math works out on yours...
and I bet it's fairly close to 22PSI...
If I can find the BFG info online, I'll post back up...
(...and I'll move this to Tires/Wheels)...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Unread 02-14-2006, 01:12 PM   #11
BigWaylon
tubework is cool...
BigWaylon's Avatar
the 32x11.50x15 BFG M/T KM is listed as Max pressure of 2535@50PSI...
2535x4 = 10140
GVWR for an SE (according to Jeep.com) is 4450 lbs for your TJ...
4450/10140 = .438856
50 * .438856 = ~21.9
sounds like 22PSI is right on target for optimum tire wear...
Greg
Unread 02-14-2006, 05:41 PM   #12
mic6
BigWaylon
you are an amazing guy!
Unread 02-14-2006, 06:01 PM   #13
method84
Im running 26 PSI all around but I am not too overly concerned because im getting rid of my 31's in another month or two
method84 is offline   Reply With Quote
Unread 02-14-2006, 06:55 PM   #14
BigWaylon
tubework is cool...
BigWaylon's Avatar
BigWaylon
funny thing is...the math for mine works out to around 14PSI...and I just can't bring myself to run them that low...so I run about 18PSI on the street...and about 3PSI on the trails...
Greg
