Air Pressure - JeepForum.com
post #1 of 7 Old 02-22-2006, 11:50 PM Thread Starter
SCDolphin
SCDolphin's Avatar
Air Pressure
What is the correct amount of air pressure to run in my 05 Ruby Unlimited.
I have added about 200 pounds with winch, tuffy security drawer skid pan etc.
Thanks
2013 Rubicon Unlimited
Hardtop/softtop
Ham W4DRH
SCDolphin is offline
post #2 of 7 Old 02-28-2006, 12:44 PM
airduds
airduds's Avatar
As much as you're comfortable with while still getting a good wear pattern. I'd guess between 26 and 32. It's very subjective though.
I run 35 on the road but that's just me. With the 10" wheels I'm getting even tire wear and it feels peppier/better handling at the higher pressure.
2000 Sport 4.0/both tops/5sp/4.88s/Dana 44 Truetrac rear/Dana 30 Aussie Locker front/Ramsey 9500 receiver mounted for front and rear/RE 5.5" LA/15"x10" M/T Classic II's/Dunlop Mud Rover 35's/TBT Alumi-Flex tie rod
airduds is offline
post #3 of 7 Old 02-28-2006, 05:30 PM
rockportbkjp
I run about 26 lbs for the last 8 months. Feels real bouncy when I put them at 32lbs.
Good luck
Larry
2005 Khaki unlimited khaki soft top
4.0l 6spd
31's BFG At's
LIGHT KHAKI JEEP CLUB MEMBER #11
NJ club member #5
rockportbkjp is offline
post #4 of 7 Old 02-28-2006, 05:33 PM
goosevodka
I run mine at about 18lbs, I had them around 30ish, and dropped them a week ago before a trail ride. Made it ALOT smoother on the street.
http://www.esentia.com
goosevodka is offline
post #5 of 7 Old 02-28-2006, 06:35 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
The best way to find out is to chalk test it. Take sidewalk chalk and color up your tread from side to side. Drive a little ways strait in a parking lot and make sure you have contact from the edges.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #6 of 7 Old 02-28-2006, 07:24 PM
Nickb1907
Nickb1907's Avatar
do this if you really want to know what to run,
remember though
to much air=center wear
to little air=outer shoulder wear
the less air you run the smoother your ride also.
Nickb1907 is offline
post #7 of 7 Old 02-28-2006, 07:26 PM
jkulbeth
jkulbeth's Avatar
remember though
And the less air you run, the lower your gas mileage. Mine drops like a rock when I get down below about 28 psi.
2004 Wrangler Unlimited, Shale Green, soft-top, Shrockwork Rocker Guards, Kumho 31x10.5 AT's
Green Jeep Club Member #119
jkulbeth is offline
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 05:52 PM
low oil pressure in 98 XJ Black89 Engines & Drivetrain 2 08-25-2006 11:24 AM
Oil pressure gone? 97wranglerkc Engines & Drivetrain 6 03-27-2006 07:44 PM
304 low oil pressure schmoken Engines & Drivetrain 5 08-24-2005 09:44 PM
Air pressure afguy Tires & Wheels 5 07-26-2005 09:32 AM
