76 cj7 wheels - JeepForum.com
post #1 of 3 Old 09-25-2013, 05:33 AM Thread Starter
Littlemudd4
76 cj7 wheels
Will stock rims off any newer jeep fit on mine? Needing some new wheels but don't need anything fancy. Craigslist has a ton of stock jeep pull offs and wondered if they'd fit.
Littlemudd4 is offline
post #2 of 3 Old 09-25-2013, 09:25 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to Tires & Wheels Forum.
The forum you posted in (JeepForum Announcements & Comments) is for questions about and help with the forum.
Wheelin98TJ is offline
post #3 of 3 Old 09-25-2013, 11:03 AM
jp360cj
1977 CJ7
You will be looking for a 5x5.5" bolt pattern. Jeeps up through an 86 CJ will fit. Wranglers use a smaller bolt pattern. Half ton fords and dodges use the same up into the mid 90 that I know of, maybe later. Would need to be an aftermarket wheel though because most of the factory ones won't fit over the CJs hubs. Also check junk yards. The trucks are usually plentiful there.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
