76 cj7 needs more flex - JeepForum.com
post #1 of 2 Old 06-15-2002, 05:08 PM Thread Starter
jepthng1
i have a stock cj7 that has almost no flex at all.
what items should i be looking at to help it flex
more?right now you cant push down at either wheel
and get it to move.
jepthng1 is offline
post #2 of 2 Old 06-15-2002, 06:14 PM
Bulletproofcj7
Sway bar quick diconnects! less than $100.( only helps the front)
A suspension lift of some sort, more than $100. depends what you are looking to do with your jeep.if you plan on doing a lot of wheeling then the above will be a good place to start.
get yourself a bunch of jeep catologs if you dont already have them and check out all of the parts and options.
Oh yeah and just surf this forum! you'll find more than enough info to keep you busy. Especially if you need to install tow hooks!
<a href="http://www.quadratec.com/" target="_blank">http://www.quadratec.com/</a>
<a href="http://www.4wd.com/index.htm" target="_blank">http://www.4wd.com/index.htm</a>
Here are two of many to get you started.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
Max. Flex vs. Useful Flex and The Anti-rock lupinsea General Jeep & Off-Road Equipment 116 03-20-2014 07:03 PM
Flex Sambox Tires & Wheels 4 07-25-2007 10:55 PM
most flex out of a cv ? 360wrangler Engines & Drivetrain 1 07-05-2007 03:07 PM
Too much flex! mudmonkey2400 General Jeep & Off-Road Equipment 20 04-17-2007 01:03 PM
Flex; How much is really necessary? makizoo General Jeep & Off-Road Equipment 17 02-10-2005 04:15 PM
