Which 37x12.50's For Daily Driver and Rock Crawling? - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Which 37x12.50's For Daily Driver and Rock Crawling?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-15-2014, 07:39 PM   #16
biffgnar
biffgnar's Avatar
Originally Posted by ryancalhoon View Post
So are they pretty quiet on the road (for a large tire), drive smooth, wear well, and good in the rocks and trails? And are they fairly accurate on their measurements - is a 37x12.50 actually going to measure around 37" tall?
I believe they are the best multi-use tire out there. Yes, on any one of those items there are better options, but overall they come out pretty well on all of them. They measure reasonably true to size. Much better than BFGs for example.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 03-16-2014, 12:13 AM   #17
ryancalhoon
2009 JK Wrangler
So what do people not like about the BFG KM's and KM2's?
Also, as far as the Goodyear MTR's, with the asymmetric tread pattern, do they have to be mounted and ran white lettering out, or can they be mounted and ran either way? (I always have white wall in.) Thanks.
ryancalhoon is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 12:18 AM   #18
justanotherjpr
Black out
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 07:53 AM   #19
mschi772
mschi772's Avatar
1997 XJ Cherokee
Argh! I was just getting ready to order the MTR's and then found out that they've apparently changed the tread design. Looks like there is 1 tread pattern on 1 half of the tire and a completely different tread pattern on the other half! Looks pretty strange! LOL. Looked into the Goodyear Duratrac but they only go as big as a 35. Local places around here are recommending the BFG KM2 or Toyo. They said they didn't see a 37" BFG Krawler available, just a 39". Hmmm.
Treadwright's Guard Dog is a clone of the original MTR and is much more affordable. Their 37's do require a 16.5" wheel, though.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is online now   Reply With Quote Quick reply to this message
Unread 03-16-2014, 08:56 AM   #20
biffgnar
biffgnar's Avatar
GY does recommend them run with a certain orientation - AT like blocks inside and MT like blocks outside. For tires that are OWL (smaller sizes) that will mean OWL out. The larger sizes are not OWL.
KM2's are over rated, undersized and poor performing compared to alternatives.
Unread 03-16-2014, 12:59 PM   #21
ryancalhoon
2009 JK Wrangler
So the larger MTR's don't have white lettering on either side then?
Unread 03-16-2014, 01:09 PM   #22
biffgnar
biffgnar's Avatar
If you go to a site like tirerack you can look at all the sizes for a particular brand and it will say whether OWL or blackwall. Initially MTR/Ks were OWL in smaller sizes (think 33 and down), but I want to say that almost all are blackwall now.
Unread 04-18-2014, 02:43 PM   #23
ryancalhoon
2009 JK Wrangler
MTR's arrived and on the Jeep! Thanks for the advice!
Unread 04-18-2014, 03:18 PM   #24
222Doc
37 and a daily? MPG is going to be GPM
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 04-19-2014, 08:44 PM   #25
ryancalhoon
2009 JK Wrangler
