37's on a cherokee? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 37's on a cherokee?
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-25-2013, 06:47 PM   #1
smurfinjeep
1991 XJ Cherokee
37's on a cherokee?
Anyone running 37's. a pic would be nice..
smurfinjeep is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 07:27 PM   #2
mschi772
mschi772's Avatar
1997 XJ Cherokee
Have you heard of Google? Click that link and go to the image section. Want just Jeepforum stuff/members? Click here.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2013, 06:17 AM   #3
wilson1010
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline   Reply With Quote Quick reply to this message
Unread 05-01-2013, 03:27 PM   #4
smurfinjeep
1991 XJ Cherokee
How do the Dana 30 axles hold up? I just recently purchased another xj I plan on building. So I want to go up a couple tire sizes.
Unread 05-02-2013, 04:54 AM   #5
wilson1010
This one has aftermarket shafts, chromoly, in the front D30 and I have a lot of restraint on the skinny pedal, so I have not had a break. I am sure it could be easily done by some of my more aggressive buddies. I can tell you that I don't shy away from any obstacle, but I also don't think more power is always the solution to a traction problem. The automatic tranny is a big help, very forgiving when a tire is stuck in rocks. I have seen 33's on Dana 44 break an axle shaft at 1500 rpm when a tire could not turn. So, if you are running a manual transmission and you like to apply the power, swap out to a Dana 44 for the front also.
Unread 05-03-2013, 01:32 PM   #6
smurfinjeep
1991 XJ Cherokee
I have an automatic trans and 4:56 gears. Most of my wheeling is at the Rubicon, slick rock, bear valley area. I have broken a stub shaft when my locker didn't disengage with 33s. So maybe ill upgrade the shafts. Whats the price range on chromos ?
