37's and 3.73? - JeepForum.com
post #1 of 12 Old 09-29-2013, 09:32 AM Thread Starter
Wranglermel
37's and 3.73?
Probably a stupid question but how awful would it be for my jeep (Tj) to run 37x10.5's with 3.73 gears? Will it hold or do I need to upgrade the gears?
Wranglermel is offline
post #2 of 12 Old 09-29-2013, 11:56 AM
222Doc
222Doc's Avatar
I can not see that working well. not just gears. few 10.5s tires out there, Interco's? made for primarily off road. you are in Florida, so mud? turning those in mud is going to test all your drive train. you must have this tj well chopped up to get 37" unless this has a 4" body lift.
222Doc is offline
post #3 of 12 Old 09-29-2013, 12:06 PM
onlyinayj89
Awful ,highly recommend not to
onlyinayj89 is offline
post #4 of 12 Old 09-29-2013, 12:13 PM
twiisted71
Depends on your set-up. I'm going to try running that set-up in my rig (12.50s though)-BUT I'm far from stock and my Tq peak is very low on the RPM/TQ curve comparatively. OD will strictly be for high speed interstate travel. If you have a gasser I'd suggest looking for an old 4 speed with the granny low. OD will be useless to you.
twiisted71 is offline
post #5 of 12 Old 09-29-2013, 07:00 PM
Chewtoy
1976 CJ5
If you are running the 4.0L in the TJ, you will probably want to go to 4.56 gears to keep your RPMs in line. Also what axles do you have? Have you beefed them up at all? Most stock jeep axles will not handle 37s well offroad. If all you are doing is crawling the mall, you will probably be just fine.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #6 of 12 Old 09-30-2013, 06:05 AM
SLADE
I ran 4.10's and 35's on my 2004 TJ for a little while. It got by, but I wasn't happy with them. It really needed at least 4.56's. I'm now running 5.13's and 37's on it.
I wouldn't even bother with 3.73's and 37's. There would be a re-gear immediately planned.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #7 of 12 Old 09-30-2013, 06:16 AM
lpukas2
X2, and I thought 3.73 with 33 was bad, that would be horrible!
lpukas2 is offline
post #8 of 12 Old 09-30-2013, 10:01 AM
biffgnar
biffgnar's Avatar
Notwithstanding the suggestions that prior posters have tried to make, it is impossible to make a proper gearing recommendation for you unless we know what year your TJ is and what transmission it has. Different gearing combinations in transmissions mean different answers for axle gearing to result in optimum final drive ratio. Overall though when considering all the possible options you might have, I don't think you are going to like 37s and 3.73.
biffgnar is offline
post #9 of 12 Old 09-30-2013, 10:46 AM
WXman
A 37x10.50? Holy crap that's going to have a ton of roll going into turns.
And that 230 lb/ft from the ancient 4.0 isn't going to be very happy with turning that leverage. I agree with everybody here...start planning for gears now. I'd actually think about 4.88.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #10 of 12 Old 09-30-2013, 11:19 AM
biffgnar
biffgnar's Avatar
Interesting point I missed the first time. Who even makes a tire that size? Isn't Interco the only one making a 35x10.5? And I don't think they have 37x10.50.
biffgnar is offline
post #11 of 12 Old 09-30-2013, 01:39 PM
WXman
I haven't ever seen a 37x10.50 with my own eyes. I was just taking his word for it that they exist. Who knows...
WXman is offline
post #12 of 12 Old 10-02-2013, 09:51 AM
tyvanwie
http://www.militarytires.com/
tyvanwie is offline
