-   Tires & Wheels (http://www.jeepforum.com/forum/f15/)
-   -   36 Swampers and Air Soft (http://www.jeepforum.com/forum/f15/36-swampers-air-soft-1532046/)
MoC 06-03-2013 08:49 PM
Anyone running 36 12.50 Swamper TSL sx bias ply's with air soft pellets? If so how much weight are you running? Been doing a bunch of reading and thinking about going this route to try to get a better balancer and get the large amount of weights off the rims. I have searched around and come up with a large range that people are recommending. The dynobead chart says 8oz. I have also seen people to 10-12 per tire on 36's.
So I guess the questions are anyone running these tires and what weight were you successful at?
Is to much a bad thing? Can I go straight to 12 oz per tire to make sure I dont do it again?
:cheers2:
schitzangiggles 06-06-2013 11:02 PM
I run 36" GY Wrangler MT (16.5" humvee tires and I am running@ 9oz of STEEL BB's in mine. Why steel BB's? denser, don't/can't clump up when you get moisture in your tire from the air compressor at the gas station and when I get a flat I unseat the bead and put a magnet in and pull them all out at once until the plug/patch dries and then put them back in.
IIRC basically a quater of a cup of steel BB's and you will be fine.
FWIW I have done this for years.
Here's a write up I did:
http://www.planet4x4.net/forums/show...5&postcount=25
The time now is 03:28 PM.
