35X15.5X15 inch super swampers - JeepForum.com
post #1 of 7 Old 11-20-2010, 09:00 AM Thread Starter
puddlehopper
i know i need a 15 inch rim but what width do i need to fit this wide of a tire
puddlehopper is offline
post #2 of 7 Old 11-20-2010, 01:33 PM
2005X
new wheel bearings every 6 months, maybe some new ujoints. oh yeah a wide *** rim also
2005X is offline
post #3 of 7 Old 11-20-2010, 01:35 PM
CONNOR_99TJ
2010 JK Wrangler
are you still using your 33s?? lol, ill take em
CONNOR_99TJ is offline
post #4 of 7 Old 11-20-2010, 06:21 PM
KKiowaTJ
A 15x10" wheel will work fine. For that wide IMO a 15x10"3.75BS minimum. That way you can still air down and they can be used with 12.50's for street.
I ran heavy krawlers for 15k and my front end is still tight. They were on steel 10" fake locks. They are a heavy 35-13.50-15 and i never had a problem. But i also keep good maintenance log. 15.50 is a little extreme on a jeep but it can be done. Be light on the skinny and have a slush fund for broken parts and up-grades.
MOPAR!
KKiowaTJ is offline
post #5 of 7 Old 12-03-2010, 10:54 PM Thread Starter
puddlehopper
yeah wut would i have to beef up in the fornt? steering column ti rods anything?
post #6 of 7 Old 12-03-2010, 11:09 PM
KKiowaTJ
A Currie or Savvy tie rod set up and sleeve. The tire is .85 thick itself. With that width you might need a hydro assist ram and ported steering box. The width is what will wear and break parts. You will need stronger front axle shafts and ujoints possibly.
Ball joints eventually but XRF's might hold up good but it all depends on your wheeling style. If its balls out your going to find out a bigger axle is cheaper in the long run. If your easy on the skinny and dont mind pulling cable now and then to save parts it can last. If you do burn up wheel bearing you can get cheap ebay ones for cheap and they are the same as a parts store unit hub. Good luck, You will have to wheel it and find out its weak links.
MOPAR!
KKiowaTJ is offline
post #7 of 7 Old 12-09-2010, 12:17 PM
rfjeeper
These are great tires,i had them on my 85 K-5 blazer,just remember these are a heavy tire,prob. gonna eat up balljoints on a jeep.I used 15-12 rim on mine but can get by with 15-10,but no smaller.Prob. gonna have tierod issues too,stock steering prob. wont cut it if you offroad alot.
rfjeeper is offline
33 inch swampers with 2 inch rough country lift Unlimited_Ma Tires & Wheels 8 06-02-2008 09:42 PM
super swampers justinwalden Tires & Wheels 8 09-24-2007 10:17 PM
which super swampers? Negative6 Tires & Wheels 5 12-31-2006 05:43 AM
Super Swampers????? BORY Tires & Wheels 7 02-10-2006 04:52 PM
Super Swampers or Super Poppers? Vacant Stare Tires & Wheels 3 08-24-2004 08:20 PM
