35's under cj7? how much lift - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 35's under cj7? how much lift
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 04-29-2003, 09:13 PM   #1
maestro
i have a 85 cj7 with 3.5 suspension lift and about and inch and a half body lift, can i fit 35 mtr's on this bad boy with a little shackle lift and some bushwacker flares?
anyone got a picture of a cj7 on 35's(mtr's or otherwise) with 5-6 inches of lifts
thanks
it's also going to be sporting full width d44's out a wagoneer if that helps anything
1985 jeep cj7,258 with mopar MPI, borla header, custom flowmaster exhaust, 1.5 inch body lift, 3.5 inche suspension lift 31inch tires,mean green alternator
maestro is offline   Reply With Quote Quick reply to this message
Unread 04-29-2003, 09:23 PM   #2
Gator
since your swapping axles, you can do a SOA & that will do the trick or you can keep what you have & put some Tj flares on it & trim them, that should clear the 35's
i had a 4" Skyjacker with 2" BL & 36 Sx Swampers, i ended up flat fendered the front
Gator is offline   Reply With Quote Quick reply to this message
Unread 04-29-2003, 11:05 PM   #3
SamFromCO
Re: 35's under cj7? how much lift
Here's a couple of pictures of my '86 CJ7. It has 4" spring lift, 1-1/2" longer than stock shackles, and TJ fender flares. I'm running 35X12.5 BFG M/T's on MTR beadlocks w/2" backspacing. You can see that the TJ flares really help with clearance.
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline   Reply With Quote Quick reply to this message
