35s on my stock Rubi wheels rub? - JeepForum.com
post #1 of 10 Old 07-03-2013, 02:34 PM Thread Starter
kitsrider
Is there enough backspacing on my stock Rubi wheels with 375/75/16 = 35s without rubbing. Currently I am running 35x12.5x15 on a 15x10 rim with 4" backspacing. They clear just fine, but stick out like a SOB.
kitsrider is offline
post #2 of 10 Old 07-03-2013, 02:40 PM
b0b11
IMO , no way
265/75/r16 rub slightly on mine at full turn
moab (rubi tj) wheels 16 x 8 , have 5" backspace
alot of people use these wheels with that tire size you want, but with wheel spacers.
b0b11 is offline
post #3 of 10 Old 07-03-2013, 02:49 PM
Jeffro06
Jeffro06's Avatar
Nope....buy some steelies with the proper back spacing, like 3.75. I don't even think a 1.25 spacer would help you with those tires, and would cost nearly as much as new steel wheels.
Jeffro06 is offline
post #4 of 10 Old 07-03-2013, 04:54 PM Thread Starter
kitsrider
Well it looks like its gonna be spacers, the rims are a the tire shop getting mounted. what do you guys use for a spacer? I am mounting these on my LJ. I see guys use Rubi wheels with 35s in the galleries.Thanks for the info.
post #5 of 10 Old 07-03-2013, 05:15 PM
b0b11
http://www.quadratec.com/products/92807_9001.htm
i know 2 people with these
dont pay attention to "84-01 Jeep" description
that makes no sense. the bolt pattern is the same up to 2006
that will get you to 3.75" backspacing on the moabs, which is a good # for those tires.
b0b11 is offline
post #6 of 10 Old 07-03-2013, 06:12 PM Thread Starter
kitsrider
I forgot to mention I have a 5.5 inch lift. 4 susp and 1.5 body.
post #7 of 10 Old 07-03-2013, 06:15 PM Thread Starter
kitsrider
My backspace is 3.75 now.
Where is the issue with fitment,rub at turn?
post #8 of 10 Old 07-07-2013, 11:51 AM Thread Starter
kitsrider
Ok I got some new 315/75/16 Duratracs mounted on my MOABs. 1.5" spacers worked perfect. Now what PSI should I run these at ? The shop put in around 34psi and they seemed hard. I dropped them down to 30PSI and going to run them like that today. Opinions? Thanks.
post #9 of 10 Old 07-07-2013, 04:52 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by kitsrider View Post
ok i got some new 315/75/16 duratracs mounted on my moabs. 1.5" spacers worked perfect. Now what psi should i run these at ? The shop put in around 34psi and they seemed hard. I dropped them down to 30psi and going to run them like that today. Opinions? Thanks.
26
Jeffro06 is offline
post #10 of 10 Old 07-07-2013, 09:23 PM Thread Starter
kitsrider
ok I will try that, thanks!
