35s on 7" wide wheels? - JeepForum.com
post #1 of 12 Old 03-04-2012, 04:55 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Title says it all, would they fit comfortably/safely?
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
post #2 of 12 Old 03-04-2012, 05:41 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Bump
Will keep doing this til people comment
-The Moderators
post #3 of 12 Old 03-04-2012, 07:31 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Bump
-The Moderators
post #4 of 12 Old 03-04-2012, 08:30 PM
FredBull
1993 XJ Cherokee
How wide are they?
Thats the key. The wider they are, the more pressure they will put on the sidewalls and help keep a bead when you air down. Usually a 10.5" tire will put a good amount of sidewall pressure, and a 12.5" wide tire will put even more pressure on the bead. I wouldnt go any wider than 12.5 on a 7" wide wheel. Not sure if there would be any repercussions, but there is almost no point to it.
FredBull is offline
post #5 of 12 Old 03-04-2012, 09:20 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Originally Posted by HokieYJ
How wide are they?
Thats true but i just want confirmation. Ive never seen 35x12.5R16s on a 16x7 wheel in person. So its all new to me.
I just bought a set of 16x7s to fit a set of tires i got free. They were 250 bucks. I still have 2 sets of 15x7 from the jeeps. I dont really feel like buying 8" wide wheels plus the ones now looks great.
-The Moderators
post #6 of 12 Old 03-05-2012, 01:07 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Bump
-The Moderators
post #7 of 12 Old 03-05-2012, 01:11 PM
LilyBayXJ
Holy bump ****. What else would you like to know? An 8" wheel would be optimal, but a 7" wheel will do on a 35" tire no wider than 12.5".
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #8 of 12 Old 03-05-2012, 04:30 PM
Eric290
A 12.5" wide tire on a 7" rim fits, but the tire suffers. A friend of mine ran this for a few years, and he told me that the sidewall developed small dry-rot type cracks faster than he thought it should.
I do know for a fact that he wore the center of the tread way down before the shoulder area of the tread.
Eric290 is offline
post #9 of 12 Old 03-05-2012, 04:41 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
Thanks guys thats all i needed to know.
-The Moderators
post #10 of 12 Old 03-06-2012, 11:18 AM
Fokkerflyer
I have a buddy that works on jeeps, 7" is pushing it, especially if you plan on doing offroading
Fokkerflyer is offline
post #11 of 12 Old 03-10-2012, 08:48 AM
WoodyHD
1983 CJ7
Where's the logic behind that? 7" will hold a bead much better than a 10".
I really don't have any personal experience to share. But In all my research I've found some people run 7" no problem and there's the people who never did it that call foul.
WoodyHD is offline
post #12 of 12 Old 03-11-2012, 08:49 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I ran 35x12.50 on 7" wide wheels for 40k miles.
No problems.
You have to run lower PSI to get even treadwear.
Wheelin98TJ is offline
