35in tires & 3.73 gear - JeepForum.com
post #1 of 5 Old 10-15-2013, 07:28 AM Thread Starter
Freemaniz
2014 JK Wrangler
I would like to run bigger wheels and tires. I would like 20in wheels and 35in tires.
What are some of the reasons i should go with smaller wheels? Also will I be OK running 35s with all stock gears/axles (3.73rear Rubicon stock ratio)
Freemaniz is offline
post #2 of 5 Old 10-15-2013, 08:26 AM
jwill
Couple of things here:
Double check your gear ratio, Rubicons come with 4.10.
Second, you're going to get much better responses in the JK tech section. But to answer your question, yes you can run 35s with your rubicon gear ratio. Whether it's efficient or ideal is a different story.
jwill is offline
post #3 of 5 Old 10-23-2013, 12:33 PM
bentbolt
That high gears for trails. Should be better on gas though driving the hwy.
bentbolt is offline
post #4 of 5 Old 10-23-2013, 01:22 PM
222Doc
222Doc's Avatar
since 2012 all AUTO rubicons are 3;73. The reason is the W580 trans has a real first gear. It pulls. The 4:10 is now optional on the auto. I have the 4:10 in ours its to much gear for the stock tires. I can still light up the 35"s if needed. at 3:73 it will be a bit harder to use 5th. Wont tow well, but Jeeps never do anyway. With the rubi in low you will be fine off road too.
I would run it with 3:73, you will use 5th less. Its way to expensive to regear that new jeep. 4:56 gears are hard to get cost a lot. 4:88 will be over geared unless you are going 37"s. If it was 37" auto I would for sure go 4:88.
For the $ the factory 4:1 is well worth the cost of the tow pack/ option. 35"s no issue, even could get away with 37" on 4:10 but you wont need 5th.
222Doc is offline
post #5 of 5 Old 10-23-2013, 09:13 PM Thread Starter
Freemaniz
2014 JK Wrangler
thx that was alot of info I appreciate it guys!!
The subtle mods make it uniquely mine without destroying the original beauty! But most people looking at the forest will never see the trees!!!!
