35 x 12.5 x 17 on stock 7.5 inch rims, is this a bad idea??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 35 x 12.5 x 17 on stock 7.5 inch rims, is this a bad idea???
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 04-24-2012, 10:42 AM   #1
socal_rubi
I went by Discount Tire last night on the way home from work, to see about getting some new shoes on my 2012 JKUR. The tire I would like to get is the Nitto Trail Grappler, 35 x 12.5 x 17. They said they can not mount that tire on my stock 7.5 inch rims, because it's too wide for my stock rims. Anyone have an input on this?
socal_rubi is offline   Reply With Quote
Unread 04-26-2012, 07:26 PM   #2
ffbtaylor
Yes they can. Im a tire dealer and that is not a problem at all. Discount tire doesnt have the brightest employees
When I die, bury me in my Jeep. Its never been in a hole that it couldn't get out of!
ffbtaylor is offline   Reply With Quote
Unread 04-26-2012, 07:31 PM   #3
ashland82391
Yeah they are a bunch of dumb As*es. They told me they I had to get all new tires because the ones I had had a couple plugs. (i didnt listen)
edit* ps those tires were 33x12.5x15 and mounted on my 8 inch wide rims just fine
Soft Door Flap Solution
[url]http://www.jeepforum.com/forum/f27/soft-upper-door-flap-solution-1438559/[/url]
Build Thread
[URL="http://www.jeepforum.com/forum/f22/bbb-black-blue-yj-build-1268543/index12.html"]http://www.jeepforum.com/forum/f22/bbb-black-blue-yj-build-1268543/index12.html[/URL]
ashland82391 is offline   Reply With Quote
Unread 04-26-2012, 07:52 PM   #4
ffbtaylor
Wow. Yeah. Plugs are fine as long as they arent in the sidewall. Glad to know you found someone to put them on!
Unread 04-26-2012, 11:19 PM   #5
jimk403
2009 JK Wrangler
Yep. Discount wouldn't mount our Duratracs either, so I bought them elsewhere.
Don't know if you have Evans Tire up in Costa Mesa, but they are cheaper than Discount too.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '88 XJ, '77 J-10
jimk403 is offline   Reply With Quote
Unread 04-27-2012, 08:15 AM   #6
ashland82391
ive had a few sets of tires mounted and balanced at walmart, never had a problem and it cost me 40-50$.
Build Thread
Unread 04-27-2012, 03:24 PM   #7
222Doc
222Doc's Avatar
the reason they may not is, you have to run a lower air preasure on the street to make up for that narrow rim and have a better contact. On a 35 a 17 inch rim has less sidewall to make up for the buldge to tire flatness. should have 8-9 on 12.5 , 10 inch is for 14.5. Disscount mounted my 15x8 on 35/12.5/15 mtr/ks no issue warrantied. have to run them at 26-27psi C rated.
222Doc is offline   Reply With Quote
Unread 04-27-2012, 05:01 PM   #8
Junky burp
Aside from the wheel being more prone to rolling (side to side) the most problem thing be is straining more for the cap (tread) for the edges...more strain for edges that are glued. Tire not has stability through sidewalls...tread not sitting square/flat...so...more strain on tread cap..maybe not so bad on bias or floatation tires (round profile) but for square flat tread cap can be more bad.. ......
Junky burp is offline   Reply With Quote
