35 in tires size rims and spacing - JeepForum.com
post #1 of 5 Old 03-27-2007, 10:51 AM Thread Starter
gardepe11
I have a 99 2.5L manual, 4.5 in RE and it is up on jacks still. I am going
to 35 in tires. Should iI go with 15X8 or 15X10 and what backspacing would
I need. Thank you
gardepe11 is offline
post #2 of 5 Old 03-27-2007, 11:01 AM
ytodd
ytodd's Avatar
tire width would help......
ytodd is offline
post #3 of 5 Old 03-27-2007, 11:06 AM Thread Starter
gardepe11
Oops. 12.50
post #4 of 5 Old 03-27-2007, 11:08 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Definitely go with a 15x8 wheel if you offroad and air your tires down. 4" or less backspacing, I wouldn't go down to 3.25" of backspacing though as some wheels like from American Eagle use. If you want to keep your tires tucked in as closely as possible you can use 4.5" of backspacing with two washers added under each of the two steering stop bolts to prevent tire rub when the steering wheel is turned all the way left or right.
You'll also need to regear your axles to 4.88 for those 35" tires and even that will be barely adequate with your four-banger.
Gone on vacation until August 25.
Jerry Bransford is offline
post #5 of 5 Old 03-27-2007, 11:19 AM Thread Starter
gardepe11
thank you, 4:88s are in with super 35, It is a trail rig not a DD
What size rims with my tires??? anro Tires & Wheels 3 06-01-2009 11:36 AM
jk rims on Xj, What size tires though? white93xj Tires & Wheels 1 04-15-2009 10:59 AM
what size tires with stock rims??? Fayettenam87 Tires & Wheels 1 08-07-2007 07:19 PM
How Can these size tires fit on these rims??? Kicken_Jeep Tires & Wheels 8 05-05-2003 08:19 PM
Size tires and Rims timdog57 Tires & Wheels 6 10-02-2002 02:59 PM
