35's and 15x10's Too wide? - Page 2 - JeepForum.com
post #16 of 28 Old 07-21-2010, 02:08 PM
TeeJay00
Originally Posted by Jerry Bransford View Post
For 13.5" wide tires like yours, a 15x10 wheel is entirely appropriate. It's for 12.5" wide tires when many of us recommend nothing wider than a 15x8 wheel.
I have 33X12.5 on 15X10.... I usually air down to 15psi !!! Of course I have only wheeled it on sand hills in the desert here.
What problems if any should I expect in rock or mud terrains???
TeeJay00 is offline
post #17 of 28 Old 07-21-2010, 02:13 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by Do It xj View Post
Yes, when I'm on a trail or going through the deep mud Im just worried about the Cosmetic effect..... NOT
Your question was "How do 35's look on 15x10 inch rims?" and you asked for pics.
Either get a pair of purpose-built beadlocks or go with 8" wide rims. I run my 35x12.5x15 KM2's at 8psi most of the time on the rocks, on my 15x8 MT Classic II's, and I've never lost a bead (knock on wood) even though I've had some raised eyebrows from a spotter or two expecting to see them torn off. Holding steady though
Deacon is offline
post #18 of 28 Old 07-22-2010, 06:25 AM Thread Starter
Do It xj
I do appreciate the info, its looking like i'll be saving up for 15x8's. but i may buy the 15x10's and flip them they are that good of a deal. 4 Bran new mickey thompson classic locks with rings, center caps, lug nuts, and 4 33x12.5 pro-comp MT with 3/4 tread for $500.
-94' cherokee sport- 2 door,5.5 inch lift,thule light bar,daylighters,bushwacked,33x12.50 BFG KM2's-sold
-99' cherokee sport-4 door-
-03' wrangler sahara- 4.5" susp, 1.25 bl/mml, w/35 BFG MT's, Flowmaster super44
Do It xj is offline
post #19 of 28 Old 07-22-2010, 01:18 PM
MickeyThompson1
Check the approved specs for the tire, but usually on a 13.50" the narrowest you should run is a 9". If you run the narrower tire you will get funky wear on the street.
JJ
MickeyThompson1 is offline
post #20 of 28 Old 07-22-2010, 01:57 PM
Deacon
Shining Adonis
Deacon's Avatar
That's not true.
Deacon is offline
post #21 of 28 Old 07-22-2010, 02:05 PM
MickeyThompson1
what's not true
JJ
post #22 of 28 Old 07-22-2010, 02:10 PM
jeepyjpsu
If its a deal you can't pass up then go for it. I did the same with 33x12.50 MTR's on ProComps knock off of the MT wheels, and got it for $450 with the tires at about 60%. It does LOOK nice, but I've never aired down past say 15-20 psi just to be safe because looking good may not get you home. Now that I'm in the market for some new MTR's I'm debating going with 33x12.50's and picking up a used set of 15x8 steelies given the fact I can afford to wheel it more (meaning I will need to be able to air down to 8-10 psi). I guess it comes down to economics in the end and the chance someone whats to get rid of some 15x8 wheels.
We Are Penn State
jeepyjpsu is offline
post #23 of 28 Old 07-22-2010, 02:13 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by TeeJay00 View Post
I have 33X12.5 on 15X10.... I usually air down to 15psi!!!
15 psi is barely airing down, I wouldn't expect any problems at that high of an air pressure. For a 33" tire, it's more common to air them down to somewhere around 10-12 psi.
Jerry Bransford is offline
post #24 of 28 Old 07-22-2010, 07:56 PM
KKiowaTJ
I run 35-12.50's on a 15x10" wheel. I have dropped it to 8psi and had no problems. I dont usually go that low as there is no reason around Iowa. But i usually put them at 10-12psi and they do great. 8" or 10" is up to what the owners wants to run. All tire dealers i have seen recommend a 8.5 to 11" wheel for 12.50's, But 8" works well for many. Good luck either way.
MOPAR!
KKiowaTJ is offline
post #25 of 28 Old 07-23-2010, 09:28 AM Thread Starter
Do It xj
well i've decided to buy them after all, if they don't work out for me i'm pretty sure i can get my money back, and 33's will be easier on the jeep untill I can regear this fall.
Do It xj is offline
post #26 of 28 Old 07-27-2010, 05:42 AM Thread Starter
Do It xj
Ok I bought the rims and tires, and have decided that the Wide look is not for me at all, now to decide between rims and 35's are there any advantages to running 16's instead of 15's?
Do It xj is offline
post #27 of 28 Old 07-27-2010, 10:55 AM
Jerry Bransford
Administrator
No, especially since you will find a better selection of 15" wheels and tires that usually cost less too.
post #28 of 28 Old 07-27-2010, 11:36 AM Thread Starter
Do It xj
I didn't think so. Prices are definately better, no just to decide what tread will fit my needs the best.
Do It xj is offline
35 , 15x10 , wheel , fit , width , wide
35x12.50's on 15x10's? ionakana YJ Wrangler Technical Forum 3 07-16-2009 07:45 AM
15x10's or 15x8's richnev TJ Wrangler Technical Forum 7 03-05-2005 09:52 AM
15x10's with 33's, did I go too wide? fcjunkie TJ Wrangler Technical Forum 5 02-04-2005 02:57 PM
15x8's or 15x10's cant decide!! ovk TJ Wrangler Technical Forum 14 09-07-2003 06:31 PM
15x10's, will they rub? Jeeper-4-Life TJ Wrangler Technical Forum 1 07-05-2002 12:04 PM
