#1 | |
33x12.5's w/ 4.5 BS?
Hey I was wondering if I could fit 12.5" tires on wheels with 4.5" backspacing or will they rub? Thanks.
#2 |
K so i found out that...how about 33x11.5" wide on 4.5 backspacing (16x8in rim)? Need help ASAP. I'll be searching for the info while i wait for a responce. just thought i'd get the question out there so maby i can be answered sooner. Thanks
#3 |
JEEP FREAK
Both 11.50 and 12.50 will fit fine.
12.50 is the max width you can run with 4.5" backspaced wheels on a TJ.
98 TJ |
#4 |
Is that the max w/ minimal rubbing or the max w/ no rubbing?
#5 |
JEEP FREAK
12.50 is the max width with minimal rubbing.
You'll have slight rubbing on the lower control arms when turning full lock, or you can add a few washers under the steering stops to prevent this.
98 TJ |
#6 |
Cool. Thanks.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
