33x12.50 bfg km2 tire pressure - JeepForum.com
post #1 of 5 Old 07-16-2013, 10:24 AM Thread Starter
Bmann412
what pressure should I have my tires at for on road use? Right now they are at 35 psi.also what psi should I air them down to for off road? I don't have beadlocks so I am assuming I can't air them down to far
Bmann412 is online now
post #2 of 5 Old 07-16-2013, 10:28 AM
WXman
How heavy is your Jeep?
I had 33x12.50-15s on my JK for a while and ran them at 25 PSI for the best contact patch. You need to see how heavy your Jeep is, then see what the total of the load capacity of your tires is. Then you'll know what percentage of their capacity you are using and you can set your PSI accordingly. Most guys will need 20-30 psi for the road depending on configuration of your vehicle.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #3 of 5 Old 07-16-2013, 10:31 AM Thread Starter
Bmann412
Not really sure the weight of my jeep but its a 4 cyl jeep tj
post #4 of 5 Old 07-16-2013, 03:25 PM
Redneck92
For on the street I would do a chalk test to see what produces the most even wear. For offroad if you have 10 wide wheels I'd go down to about 15 psi if you have 8 wide wheels I'd go down to 12 psi.
86 4Runner "The Turtle" - 22RE 5spd, duals, Dana 60, 14 Bolt SAS on jackstands
02 Tacoma - 3.4 5spd TRD
Carolina Trailblazers
Redneck92 is offline
post #5 of 5 Old 07-17-2013, 07:07 AM
medijeep
agreed.
I've found that on my 35" KM2's on 8 inch rims that 27 psi is the magic # for street. And 10-12 psi for off road. We do a lot of wet rocks up here. Never popped a bead so far.
medijeep is offline
