33x12.5 Yokahama's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 33x12.5 Yokahama's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 10-07-2012, 10:11 PM   #1
PhAnderson
33x12.5 Yokahama's
im getting 33x12.5 Yokahama's for my xj that has 4.5' Rough Country lift.
now will these tires fit fine? or do i have to do some type of cutting or moding?
PhAnderson is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 09:13 AM   #2
TellicoTJ
Should fit fine. A buddy of mine had 32x11s on his xj with the same size lift and he had plenty of room for 33" tires. worst case scenario, if they dont fit you might have to trim a very minor amount on the fender.
2.5 Liter club memer #169-Red Jeep Club meber #491
Originally posted by: Jeremy93yj To coax out the poop, try rocking back and forth. If that doesn't work, try rocking side to side. Hold your cheeks apart with your hands while you push and scream at the top of your lungs. I also like to put my feet up on the wall and push against the toilet. Another way is to sit on the pot, reach down and grip the bowl with both hands, and push against the floor with your feet.
TellicoTJ is offline   Reply With Quote Quick reply to this message
cheroke , help needed , tires rubbing , xj
