33x10.50 BFG MT on Ravines - JeepForum.com
post #1 of 9 Old 08-31-2007, 09:26 AM Thread Starter
mikey6345
Anyone running this setup? I am starting to like the look of the skinnier tire. I run 32x11.50 BFG ATs right now with spidertrax spacers. My thought is with the 10.50 I can get rid of the spacers and tuck the tires back under the flares.
The spray from my current tires outside of the flares can be a bit of an issue when I drive to work with no doors.
If you run the 33x10.50 on Ravines do you rub or would I need to keep the spacers?
Thanks all!
Mike
mikey6345 is offline
post #2 of 9 Old 08-31-2007, 09:34 AM
Crashnburn80
Crashnburn80's Avatar
It'll be close but you should be able to get away with it. At worst you will just need some spacers on the steering stops to prevent rubbing at full lock.
Edit: although to go to 33s you should also add a 1.25" BL for proper fender clearance.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 9 Old 08-31-2007, 11:24 AM
jayr
jayr's Avatar
Here is mine with that exact setup awhile ago. I did have at least one washer in the steering stops with RE LCAs and two when I had stock LCAs (am now on black steelies w/ 3.75 BS):
jayr is offline
post #4 of 9 Old 08-31-2007, 12:19 PM
sardog12
sardog12's Avatar
Wouldn't the taller tire have a better chance to rub than a smaller tire of the same width (ie. 31x10.5 vs 33x10.5) at full turn?
GEAUX TIGERS
sardog12 is offline
post #5 of 9 Old 09-01-2007, 12:11 PM
FXSTCHEWY
FXSTCHEWY's Avatar
I had AT's on Ravine's....31 x 10.5", They didn't rub at all. Chewy
"To preserve liberty it is essential that the whole body of the people always possess arms and be taught alike, especially when young, how to use them." -- Senator Richard Henry Lee, 1788
- Wannbe Old Guy Jeep Club Member
-06' Unlimited,3" BDS/Zone,American Eagle 185's,Cooper St's 33x12.5's,Ramsey 8.5,Tomken,Jeeperman,Warrior,Tuffy, Pioneer.
FXSTCHEWY is offline
post #6 of 9 Old 09-01-2007, 12:56 PM
otisdog
2008 WK
I don't know - I put my 33 x 10.50's on Gamblers which are the same backspacing and they were way too close to the upper rear spring perchs for my liking. I put on spacers.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 9 Old 09-02-2007, 08:05 AM
vinsonrider
Anymore input on ths subject?
vinsonrider is offline
post #8 of 9 Old 09-03-2007, 09:47 PM
airframer
airframer's Avatar
i have 12.5s and spider spacers and i got about 1 inch from my rear upper spring pearch. i would not wanna go ne closer. plus the ride imrpoved after the spacers. wider wheel base=more stability
Everything in moderation
airframer is offline
post #9 of 9 Old 09-04-2007, 09:04 AM Thread Starter
mikey6345
I looked up in my wheel well yesterday and it looks like there would be enough room with 10.50s without the spacers. I have 11.50s right now with spacers so it seems that the net change would push the wheel in about 1" max. I think I may measure my current tires without the spacers in the next week or so.
Painted Ravines 35sUnlimited Tires & Wheels 108 10-30-2013 07:06 PM
32x11.5's on ravines SOLIDJP44 Tires & Wheels 4 08-02-2009 09:41 AM
can I put these on ravines? Also... Longspoon Tires & Wheels 1 07-02-2008 10:30 AM
Painted Ravines Wazinga Tires & Wheels 6 09-03-2007 06:17 PM
Ravines and 33x12.5 cdsptatc Tires & Wheels 0 09-01-2005 10:38 AM
