33's on a yj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 33's on a yj
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-25-2014, 09:27 PM   #1
NHYJ4213
33's on a yj
Would these tires fit correctly on a stock 4.2 laredo YJ rim?
http://www.tirebuyer.com/tires/micke.../p/tv126000107
NHYJ4213 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 12:18 PM   #2
swirve
What size? I believe you wont have issues with a 33 10.50 but probably will with a 33 12.50
swirve is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 12:30 PM   #3
NHYJ4213
They were 33x12.50x15's... but I realize that the rims i have are 15x7 and too small for the 12.50...
Unread 01-26-2014, 07:52 PM   #4
apaTJ
You'll want a lift and rims with less back spacing, or wheel spacers.
apaTJ is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 09:14 PM   #5
NHYJ4213
I plan to do a 4" zone off road lift, would that be enough? or add 1" body lift as well? And I hear a lot of negative reviews on wheel spacers, for stress on the studs.
Unread 01-27-2014, 09:31 AM   #6
apaTJ
4 inch would be enough. If you don't want spacers just get new wheels with 4 inch backspacing. You can get steel wheels for around 200 a set
Unread 01-27-2014, 12:10 PM   #7
NHYJ4213
Thanks :P
Unread 01-29-2014, 12:52 PM   #8
NHYJ4213
I found some 15x8 rims I like with -13mm offset and 3.976 of backspacing.. would those handle the 33x12.50s?
Unread 01-29-2014, 07:04 PM   #9
apaTJ
Ya that's exactly what your looking for
Unread 01-29-2014, 08:30 PM   #10
NHYJ4213
awesome thanks!.. I actually like how they look too, and they're cheap!
