33 MTR/K vs. 35 MTR/K - JeepForum.com
post #1 of 5 Old 05-01-2013, 04:37 PM Thread Starter
JEEPER188
I need new tires soon and I am currently running 33 Bfg At. So should I stay with 33s or go with the 35s because I can get them a little cheaper. If I did go with the 35s how much mpg would I aspect to loose and would I see a noticeable power loss with the inline 6 ? I have 3.73 gears and I do not plain to regear with these axles.
Side note: I do have upgraded steering and brakes.
/ l ,[____],
l-----l-ollllllo-
()_)_()_)-o-)_)
JEEPER188 is offline
post #2 of 5 Old 05-01-2013, 05:39 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
I don't run 35s, but here is the original MTR thread as I'm sure you'll find comments about 35s there.
http://www.jeepforum.com/forum/f15/g...kevlar-716506/
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #3 of 5 Old 05-01-2013, 05:41 PM
KKiowaTJ
Either way will be driving around with the o/d off. So id go with the 35's, You have the 44, Steering and brakes. If you going to take a dig, Might as well run the bigger of the two.
You will most likely see a 1-2mpg drop. To each his own though, Good luck
MOPAR!
KKiowaTJ is offline
post #4 of 5 Old 05-01-2013, 05:55 PM Thread Starter
JEEPER188
Thanks guys for your input.
/ l ,[____],
l-----l-ollllllo-
()_)_()_)-o-)_)
post #5 of 5 Old 05-01-2013, 06:21 PM
SLADE
Stay with 33's, they will be cheaper and more comfortable in the long run.
I wouldn't conside running 35's with less than 4.10 gears.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
