33 Engineering HC Trans Mount and Tumy Skids
#1 | |
Anyone running either? How was the install? Any vibes afterwards?
Thanks
JEEPLESS... :( |
#2 |
I'm running both in a 2005. I have a 1" BL & 1" MML. I don't have any vibes from the drivetrain. I did have vibes from the exhaust hitting everything and chose to replace it with smaller aftermarket parts.
2005 Impact Orange Rubicon 6 speed standard 4.0L I6 engine Mechanical Engineer behind the wheel Toronto, ON, Canada |
#3 |
Do you have any pics showing your TT and all that?
Thanks!
JEEPLESS... :( |
#4 |
No good pics... I will take some this week.
#5 |
Cool. Thanks!
JEEPLESS... :( |
#6 |
Ahhh, another thing on the "to do " list!! Was the exhaust hitting gas tank skid or erevything in reach?
04 L J Travel'n Gadget Show KE5PPH |
#7 |
The MML raised the front part of the exhaust until it hit the passenger side upper control arm. Then the skid itself pinched the cat between it and the underside of the body. Also, the muffler was rubbing on the trailing edge of the skid plate. Other than that... everything was ok.
The aftermarket parts were much smaller and I had the exhaust piping redone from the header all the way back in 2.5". Now it misses everything and I shortened the tailpipe so it won't hit anything on the trail.
#8 |
Soooo If I get a big piece of flex - pipe I'll be good to go!!!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
