33-12.50's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 33-12.50's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-13-2013, 10:39 PM   #1
HOSS_79
33-12.50's
What is a good lift for a 4 door jeep wrangler. It has a V6. I don't want to go bigger than 33's and want them to stick out of the fenders slightly. I don't do much off roaring. Usually just to the beach. Mainly on the hwy. also what do I need to consider when putting a bumper and winch on. Will it weigh the front end down too much. I would also like to see any pics. Thanks
HOSS_79 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2013, 07:19 AM   #2
biffgnar
biffgnar's Avatar
Really should fill out your full profile so people can help you better. You'll find a lot of threads, pictures, etc. if you go to the JK Tech section. A lot more than here in Tire section.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
