32x11.5's on ravines - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 32x11.5's on ravines
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-18-2008, 09:32 PM   #1
SOLIDJP44
can u run 32x11.5s on stock ravine wheels and be ok for daily driving
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2008, 07:10 PM   #2
gus54
You may have some slight rubbing at full turn unless you add wheel spacers. I run a 2" lift with 32s on 4.25 BS with no rub. Your wheels are like 5.5 BS I think.
gus54 is offline   Reply With Quote Quick reply to this message
Unread 09-20-2008, 10:42 AM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its going to be pretty tight around the upper coil perch in the rear.
If you have a small suspension lift and your rear axle is not perfectly centered, it will make the problem worse.
You can trim away a little of the coil perch if it rubs.
It will rub when turning full lock too. You can adjust the steering stops or just deal with the rubbing. This will of course increase your turning radius.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 09-22-2008, 01:01 PM   #4
BulldogTJ98
Mine rubs a teeny weeny bit when its flexing in the rear, but its nothing to worry about. Ive been wheeling them for a long time. There is no marks on the tires anywhere.
[B]My Build Thread: [url]http://www.jeepforum.com/forum/showthread.php?t=587503[/url][/B]
[SIZE="2"][B][COLOR="Orange"]'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar[/COLOR][/B][/SIZE]
BulldogTJ98 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2009, 09:41 AM   #5
Colt
I'm running BFG 32x11.50's on Ravines with only a 2" BB.
Very close to the rear spring perch but not rubbing.
I did have to adjust the steering stops though.
"667" Neighbor of the Beast
Colt is offline   Reply With Quote Quick reply to this message
