32x11.5's on ravines - JeepForum.com
post #1 of 5 Old 09-18-2008, 08:32 PM Thread Starter
SOLIDJP44
can u run 32x11.5s on stock ravine wheels and be ok for daily driving
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #2 of 5 Old 09-19-2008, 06:10 PM
gus54
You may have some slight rubbing at full turn unless you add wheel spacers. I run a 2" lift with 32s on 4.25 BS with no rub. Your wheels are like 5.5 BS I think.
gus54 is offline
post #3 of 5 Old 09-20-2008, 09:42 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its going to be pretty tight around the upper coil perch in the rear.
If you have a small suspension lift and your rear axle is not perfectly centered, it will make the problem worse.
You can trim away a little of the coil perch if it rubs.
It will rub when turning full lock too. You can adjust the steering stops or just deal with the rubbing. This will of course increase your turning radius.
Wheelin98TJ is offline
post #4 of 5 Old 09-22-2008, 12:01 PM
BulldogTJ98
Mine rubs a teeny weeny bit when its flexing in the rear, but its nothing to worry about. Ive been wheeling them for a long time. There is no marks on the tires anywhere.
My Build Thread:
'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar
BulldogTJ98 is offline
post #5 of 5 Old 08-02-2009, 08:41 AM
Colt
I'm running BFG 32x11.50's on Ravines with only a 2" BB.
Very close to the rear spring perch but not rubbing.
I did have to adjust the steering stops though.
"667" Neighbor of the Beast
Colt is offline
32x11.5s on ravines or canyons pictures please SOLIDJP44 Tires & Wheels 0 07-22-2008 08:57 AM
can I put these on ravines? Also... Longspoon Tires & Wheels 1 07-02-2008 09:30 AM
33x10.50 BFG MT on Ravines mikey6345 Tires & Wheels 8 09-04-2007 08:04 AM
Painted Ravines Wazinga Tires & Wheels 6 09-03-2007 05:17 PM
Ravines and 33x12.5 cdsptatc Tires & Wheels 0 09-01-2005 09:38 AM
