32 x 11.5 on 15 x 8" - JeepForum.com
post #1 of 6 Old 09-01-2012, 11:34 AM Thread Starter
jhrebs
1987 YJ Wrangler
Will a 32x11.5 tire fit on a 15 x 8 rims? Anybody seen this before? do you know what this will look like? Any pictures?
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 6 Old 09-01-2012, 12:07 PM
biffgnar
biffgnar's Avatar
Will be fine
biffgnar is online now
post #3 of 6 Old 09-07-2012, 09:18 PM
My03tj
Yup on my rig with no problems. Just make sure your back spacing is correct. I have 3.75 and no problems
My03tj is offline
post #4 of 6 Old 09-08-2012, 06:00 AM
SuperJohn
I know it's not what you are asking for but I have 33-12.50-15's on an 8 inch rim. The tire dealer said they might not work so I told him to do it anyway it would be fine and what do you know they were fine.
SuperJohn is offline
post #5 of 6 Old 09-08-2012, 11:53 AM
TellicoTJ
Generally 4" wider tires than the wheel is as far as you should go (8" wheel/12" tire, 7"/11" tire...) but many have gone 5" wider tires than the wheel. I have 11" wide tires on 8" wheels and it holds the bead fine at 10-12psi but lower tire pressure can be run.
2.5 Liter club memer #169-Red Jeep Club meber #491
Originally posted by: Jeremy93yj To coax out the poop, try rocking back and forth. If that doesn't work, try rocking side to side. Hold your cheeks apart with your hands while you push and scream at the top of your lungs. I also like to put my feet up on the wall and push against the toilet. Another way is to sit on the pot, reach down and grip the bowl with both hands, and push against the floor with your feet.
TellicoTJ is offline
post #6 of 6 Old 09-08-2012, 12:50 PM
222Doc
222Doc's Avatar
Running tires like this is ideal off road. depending on the ratio of side wall. I would not do this if you say running 20"s on 35"s. not enough side wall to make up in the pinch, well unless we are talking 40+ tires on 20"s but by then the rim is 10-12 inches and still not as wide as a 14.5.
ON road where you loose is, you will have to run a lower PSI than what is on the Jeep or the tire. mpg and some side wall stabilty.
222Doc is offline
3" x 4" or 2" x 4" rectangle tube for rear bumper with swing out? linexrandy Fabrication Shop 11 06-24-2011 10:43 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty Audio, CB & Ham Radios, GPS, & Electrical 6 03-05-2010 07:27 AM
Keyless entry "honks" instead of "chirps" Holder350 Audio, CB & Ham Radios, GPS, & Electrical 1 01-17-2010 07:46 AM
GE "High Output" or GE "Cool Blue" headlights? itasor Street Jeep Forum 25 09-24-2007 11:57 AM
"Posi" carrier vs "Open" in Dana 35? Big92Jeep General Jeep & Off-Road Equipment 6 11-18-2001 03:24 PM
