31s on stock ZJ - JeepForum.com
post #1 of 7 Old 10-20-2011, 01:14 PM Thread Starter
OneWhiteDoor
1987 YJ Wrangler
31s on stock ZJ
Can you fit 31s on a stock ZJ Grand Cherokee? Im asking this because a friend of mine has 30x9.50x15s on her ZJ and they seem to have enough clearance to fit a 31 on there. It'd really be calling it close and I bet itd rub a lot though.
Im at a point where I need to replace the tires, but dont have a lift kit on the jeep yet. Been thinking about a simple 3.5 inch lift, but need new tires first. Can I get by with 31s on the stock Zj until I buy the lift in a few months?
Or lift first then 31s
OneWhiteDoor is offline
post #2 of 7 Old 10-20-2011, 04:06 PM
Mike97ZJ
They'll rub, you'll need totrim some plastic off the front bumper.
Even with 3" of lift I had to trim my bumper a bit when I went to 31's.
And if these are going on stock wheels, it's possible they'll rub the lower control arms at full steering lock.
If at all possible, I'd wait to lift it before you go with the 31's.
Mike97ZJ is offline
post #3 of 7 Old 10-21-2011, 09:57 AM Thread Starter
OneWhiteDoor
1987 YJ Wrangler
Ok, waiting for the lift is the best option anyways
post #4 of 7 Old 10-21-2011, 05:40 PM
KKiowaTJ
They fit for me when on my old 96' ZJ. All i had to do was pound the fin flush in the wheel well behind the tires. The only place they might rub is the LCA's and that can be adjusted or just dont turn too sharp.
To each his own but it dont take 3+ inches of lift for a 31" tire. The budget swap allowed for 285's to fit and flex fine. Good luck either way
MOPAR!
KKiowaTJ is offline
post #5 of 7 Old 10-22-2011, 12:49 AM
HeavyArms
This
With stick rims youl be fine. Just rub on the lca's ga bit
Wiggle wiggle wiggle
HeavyArms is offline
post #6 of 7 Old 10-22-2011, 09:42 AM
mojop79
I have a zj with 2" bb and just put on 32" Wildpeaks. I needed to trim front and rear. Ended up taking off front bumper. Trimmed my rear fenders. Had to if i wanted any wheel stuffing without ruining my tires. I do rub on LCA at full lock and the sway bar a little. Getting some new wheels with correct bs will solve that issue.
mojop79 is offline
post #7 of 7 Old 10-27-2011, 03:48 PM
samuel827
1994 ZJ
i put 31's on my 94' and didnt have to trim anything, but at full wheel lock they hit my lca's.
samuel827 is offline
Can I change my stock tire size while keeping the stock rim? 04Overland47 Tires & Wheels 0 09-26-2011 06:41 PM
94 Jeep Cherokee Sport, stock rims winter tires Is smaller then stock an issue? brahm Tires & Wheels 6 01-07-2009 02:31 PM
Stock Rubicon: Any experience with pure stock plus front disconnects godell Tires & Wheels 10 06-06-2005 10:26 AM
1997 ZJ Swapped stock cassette for stock CD, and have a problem.... doccjp Audio, CB & Ham Radios, GPS, & Electrical 0 03-25-2004 07:07 PM
