315/70/17 Nittos what air pressure are you running - JeepForum.com
post #1 of 3 Old 07-29-2012, 11:40 AM Thread Starter
silverrr
Just got today Nittos trail grappler MT in 315-70-17 for my 4 door JK rubicon ,the tire shop got them at 30psi , they look like they can use some more pressure what I notice and read in a review was how much heavier they felt when rolling the jeep , dont know if this is the nature of the tire or it needs more air . What are you running your 35's or 315's for optimun street use??
Cris
silverrr is offline
post #2 of 3 Old 07-30-2012, 03:39 PM
WJ910
we put 33psi in them. 35 wont hurt either.
WJ910 is offline
post #3 of 3 Old 07-30-2012, 07:23 PM
ltrail
1984 XJ Cherokee
I say chalk test. Pressure will vary from vehicle to vehicle. If you asked the manufacturer theyd want vehicle weight along with all the mods that may make them heavier.
Get sidewalk chalk, color a good portion of the tread(nothing crazy just a couple inch wide astripe across), Drive in straight line on fairly flat surface 50ft (get quite a few good rotations out of the tire).
If the center wears it means less air, if the outside edges both wear it needs more.
Take the air up or down ~2-3psi each run. When chalk wears off the tire evenly across the whole tire you've found the optimal setting for your rig.
I run ~28psi front/~25 rear
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
what can i air my nittos down to safely off road? monkers Tires & Wheels 1 07-24-2012 01:08 PM
Pitbulls, nittos, or yokohomas 2000sport Tires & Wheels 4 05-11-2012 06:29 PM
17x8 and Nittos 33x12 Mud Grapplers? broberts001 Tires & Wheels 6 02-05-2009 02:26 PM
How much pressure are you guys running on your 35's? method84 Tires & Wheels 4 04-30-2006 06:18 PM
What tire pressure are you running?? N5RMQ Tires & Wheels 5 01-14-2005 01:20 AM
