3" TJ lift questions - JeepForum.com
post #1 of 3 Old 12-22-2005, 10:11 AM Thread Starter
limecolbyjack
limecolbyjack's Avatar
ok im doing a rustys 3" lift springs in the front with 3/4" spacers. and the rear rustys coils, with swaybar extensions in the rear and the rear track bar bracket. i also got the extended brake line brackets.
my question is do i need longer brake lines with a 3" lift or with the extensions will i be ok? i have the 2" BB shocks as of now. but does monroe or someone make longer shocks for the TJ that i can get at like napa or autozone? all the after market shocks seen real pricey.
hopefully ill get the 1" BL and MML soon also. but will i have any shifting into 4LO problems. its a 04 auto TJ thanks. any info or help would be appreciated. -chris
2004 TJ for me
2006 Grand for her
jeep stuff great prices and service - DK 4 Wheel 309-736-0056
limecolbyjack is offline
post #2 of 3 Old 12-22-2005, 10:55 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Your brake lines will be fine.
There are a few shocks out there that are cheap and ride pretty good:
-Skyjacker Hydros (NOT Nitros)
-BDS
They'll run you around $30 each.
Wheelin98TJ is offline
post #3 of 3 Old 12-23-2005, 08:53 AM Thread Starter
limecolbyjack
so even if i run 3" shocks the extended droop wont hurt the brake lines then. also i seen some lifts come with extended bump stops. does one need these or is it just for big tires on small lifts?
i seen on autozones website for $20 u can get lifetime warrenty shocks for 3,4 or 5" lift TJ's. thought that was interesting. -chris
2004 TJ for me
2006 Grand for her
Re la 5.5" lift questions sixpointoh03 Tires & Wheels 1 01-14-2008 02:21 PM
Questions on 2" BDS lift Bishop Creek Tires & Wheels 11 08-01-2007 05:23 PM
Installing a RE 3.5" lift on an XJ and had a few questions.. webqaz Tires & Wheels 4 12-23-2006 04:30 PM
OME 2.5" HD spring lift questions martinsburgjeep Tires & Wheels 11 05-26-2006 04:16 PM
RE 7.5" lift questions joshmacc Tires & Wheels 5 08-28-2005 03:56 PM
