Quantcast 3" body lift + 3" suspension? good or bad? need tire help also. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 3" body lift + 3" suspension? good or bad? need tire help also.
Old 07-13-2008, 01:48 PM   #1
mrbriteside1465
I own a 1994 Jeep Wrangler. It is in decent shape, has a good suspension system and american racing wheels. The tires are a mix of 3 bf goodrich A/T and 1 other A/T. They tires are 31". The jeep has a 3-4" body lift, but no suspension lift. I'm looking to upgrade to 33" tires. If I go offroading it is very light mud or sand. I drive more on streets than I do offroad. What are the best tires for me?
Also, as far as the lifts go..I would much rather have a 4" suspension lift than a 3" body lift, which I already have. I went offroading recently, and bottomed out almost instantly. Is there any way that I could do a 3" suspension lift on top of the body lift? Would that be too much? Or should I drop the body lift down to about 1" and then do the 3" suspension lift. If I do the suspension on top of the body lift, that would be almost 6-7 inches. Plus the 33" tires would raise it another 2". That sounds like a lot, but if it will work safely without flipping...I'd go for it.
Any help on this topic would be greatly appreciated.
-Sean
mrbriteside1465 is offline   Reply With Quote
Old 07-13-2008, 02:19 PM   #2
Jebussaves0
3" is a LOT of body lift. I wouldn't run more than 1" of body lift on a jeep I owned.
Drop it down to a 1" BL and mess with the suspension from there.
Jebussaves0 is offline   Reply With Quote
Old 07-13-2008, 05:48 PM   #3
84jeepjohn
I agree drop it to a 1" BL (I'll plug daytstar) and do a 4" lift. hell you might be on the small side with the 33's at that point.
I know it's a CJ but the same rules aply for the CJ and YJ Here's mine with the 4.5" lift and 1" BL and TJ flares and 35's
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline   Reply With Quote
Old 07-14-2008, 12:33 AM   #4
Finulanu
If your going to be wheelin' in light mud and sand, I would suggest the BFG A/T.
Finulanu is offline   Reply With Quote
Glock Forum
