285/75r18 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 285/75r18
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-24-2015, 11:33 AM   #1
SLADE
285/75r18
Any one running a 285/75R18?
How do they actually compare height wise to a standard 35x12.50?
Their labeled specs put them a little taller than most standard 35's and am curious how they actually measure up.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now   Reply With Quote Quick reply to this message
Unread 01-29-2015, 06:26 AM   #2
SLADE
Any body?
With the lack of tall narrow tires, I figured there would be a few people running them. Seems like an appealing size for JKs with factory 18" wheels.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 01-29-2015, 05:23 PM   #3
jadmt
2014 JK Wrangler
in toyos the 285/75-18 is taller then the toyo 35/12.5-17 for AT2's/ They are a 34.8 tall and 11.3 wide. Nice tire size really.
jadmt is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 08:01 AM   #4
SLADE
Yea I like the size and it's available in a Nitto Trail Grappler, Toyo Open Country MT, and Goodyear MTR/k.
Between the 285/75R18 and the 315/70R18 (36x12.50) Toyo Open Country MT, 18's are looking a little attractive for a DD/ weekend warrior.
Down side is they are all load range E and have quite a bit of weight to them.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread Yesterday, 08:53 AM   #5
jadmt
2014 JK Wrangler
If you are putting them on a 4 door you will be fine. I run Toyo E rated AT2 in 35's and they are great you just need to run them at 26-28psi. The 285/75-18 Toyo in AT2 EX is only 65lbs.
