265 60 18 or 265 50 20 tire's on Grand Cherokee 2009 ( WK ) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 265 60 18 or 265 50 20 tire's on Grand Cherokee 2009 ( WK )
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-29-2012, 06:03 AM   #1
apood
- i want to Installation 265/60R18 Tire's on my Grand Cherokee overland 2009 ( WK ) on my original wheel's 18*7.5 inch , Are there any problems ? rubbing ? any one try this before , How was it ?
- I'm thinking also to Installation 265/50R20 Tire's with New wheels ( WK2 ) 2011 Grand Cherokee 20*8 inch , Are there any problems ? rubbing ? any one try this before , How was it ?
apood is offline   Reply With Quote Quick reply to this message
Unread 03-29-2012, 09:06 PM   #2
just501
2008 WK
Must address the bolt. I used appx .6" true spacers with longer studs. No other rubbing issues with 265/50/20 size. The wk2 20" wheels are 1/2" wider and nearly all of it is to the inside of the wheel.
'08 WK Overland 5.7 HEMI QDII
'99 WJ Limited 4.7 QTII
'68 Firebird 400 4-Speed
just501 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2012, 05:30 AM   #3
apood
thanks for replay ,,,,
what's the bolt Must i address ? can u Explain to me by pic ? How many of those bolt ?
Unread 03-31-2012, 01:50 PM   #4
apood
Unread 04-01-2012, 11:05 AM   #5
just501
2008 WK
http://www.jeepforum.com/forum/f67/2...rrains-630395/
Loook at the bottom of the first page, one per side.
Unread 04-02-2012, 09:21 PM   #6
apood
? what now
Unread 04-02-2012, 10:20 PM   #7
just501
2008 WK
Originally Posted by apood View Post
? what now
The first pic in post #15 shows the ball jt bolt that will contact the tire (wk2 20" wheels with 265/50/20) if you do not address it, i.e. cut it or space the wheel away from it. There is one on each side.
Unread 04-03-2012, 08:45 PM   #8
apood
if i cut the bolt only can i Install 265/60R18 Tire's on my original wheel's 18*7.5 inch Without rubbing ????
or
Install 265/60R20 Tire's with wheels ( WK2 ) 2011 Grand Cherokee 20*8 inch Without rubbing ???? are you sure ????????
Unread 08-17-2013, 11:18 AM   #9
Uplandfarmohio
265/60R20 on WK2 Overlannd
Just wondering how the 265/60R20s looked on the WK2. Can you post a pic?
Anyone else done this and have a pic? Hoping to put bigger tires on without new wheels.
thanks!
Uplandfarmohio is offline   Reply With Quote Quick reply to this message
