245/75/16 Duratrac Load C Tire Pressure - JeepForum.com
post #1 of 3 Old 10-05-2012, 05:19 AM Thread Starter
sporticon03
I have an 03 TJ with a new set of Duratracs. They are replacing stock MTRs of the same size.
I'm not sure if I should run the same pressure (33) because the MTRs were load range E. is it normal to have to go with a higher or lower pressure with a lighter tire?
They ride nicely at 33 but I'm seeing a decrease in MPG and they don't appear to be much more aggressive.
Anyway, a lot of people are running this tire on a 15 inch rim but I'm looking specifically at the stock rubicon size.
I'm not a huge fan of the chalk test or calculations based on weight. I feel like they always end up on the low side.
Thanks!
sporticon03 is offline
post #2 of 3 Old 10-10-2012, 03:08 PM
tjtrucker
If you're not wanting to do the Chalk test, then it's just trial and error till you get what you want. everyone's jeep is different. I have the Duratrac 33x12.50x15s I run mine at 26 PSI- cold.
tjtrucker is offline
post #3 of 3 Old 10-10-2012, 03:11 PM Thread Starter
sporticon03
I suppose. I was hoping other people are running the same size tire. If I had faith in the chalk test i would.
duratrac , mtr , rubicon , tire , tire pressure
