-   Tires & Wheels (http://www.jeepforum.com/forum/f15/)
-   -   245/75/16 Duratrac Load C Tire Pressure (http://www.jeepforum.com/forum/f15/245-75-16-duratrac-load-c-tire-pressure-1424330/)
sporticon03 10-05-2012 05:19 AM
I have an 03 TJ with a new set of Duratracs. They are replacing stock MTRs of the same size.
I'm not sure if I should run the same pressure (33) because the MTRs were load range E. is it normal to have to go with a higher or lower pressure with a lighter tire?
They ride nicely at 33 but I'm seeing a decrease in MPG and they don't appear to be much more aggressive.
Anyway, a lot of people are running this tire on a 15 inch rim but I'm looking specifically at the stock rubicon size.
I'm not a huge fan of the chalk test or calculations based on weight. I feel like they always end up on the low side.
Thanks!
tjtrucker 10-10-2012 03:08 PM
If you're not wanting to do the Chalk test, then it's just trial and error till you get what you want. everyone's jeep is different. I have the Duratrac 33x12.50x15s I run mine at 26 PSI- cold.
sporticon03 10-10-2012 03:11 PM
I suppose. I was hoping other people are running the same size tire. If I had faith in the chalk test i would.
The time now is 05:34 AM.
