2005 Jeep tj unlimited wheels - JeepForum.com
post #1 of 4 Old 11-26-2013, 08:13 PM Thread Starter
devo1
Thanks for the help, I'm wanting to put on different rims and bigger mud tires, with no lift how big can I go with a 15in rim without running into problems? Any suggestions on where to look?
devo1 is offline
post #2 of 4 Old 11-26-2013, 08:23 PM
AntiPrius
A 31" (31x10.5x15) is the biggest you can go with no lift, and no other alterations such as cutting sheet metal. With a simple budget boost, you may get 32's on it.
AntiPrius is offline
post #3 of 4 Old 11-26-2013, 08:27 PM
2jhanna
I don't think this is what the OP is asking,
I believe he's asking if he can put a 12.5" wide tire on a 8" wide rim, or something along these lines as to the widest tire he can put on a stock rim.
Now, don't forget that if you use stock rims with oversize tires, you will need spacers. that's why most change wheels to get different backspacing.
edit: just re-read OPs post, AntiPirus, he is asking more than 1 questions. Your answer was good.
jhanna
denton county, tx
2jhanna is online now
post #4 of 4 Old 11-26-2013, 09:27 PM
PhulesAu
Telling to use the search, would have been a better answer
PhulesAu is offline
