2?-speed with 305/70 16 . . . transfer case lowering kit - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 2?-speed with 305/70 16 . . . transfer case lowering kit
2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub AsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 08-16-2007, 10:18 PM   #1
99wrangler4x4
i want to thank everyone for answering all of my questions but now i have two more. i got my tires on today 305/70 16 but have not ordered the speedo gear so does anyone have a clue of how much faster im going than what the speedo says? and my second question is about the transfer case lowering kit. the bolt holes do not line up (yes i have them on the right way because if i turn them around the holes would be way off) so i could either drill them right or leave them off. i heard if i leave them off it will cause vibrations- are the vibrations really bad? and will it cause too much stress on my drivetrain?
99wrangler4x4 is offline   Reply With Quote
Unread 08-17-2007, 03:55 PM   #2
JEEP97TJ
I just moved up tire sizes too. Now, did you change axle gears when you changed tire size also?
Correct speed (with same gear ratio) = new tire diameter/old tire diameter
x speed
For me, 31 inch tire / 28 inch tire x 70 mph = 77.5 mph.
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Unread 08-18-2007, 12:00 AM   #3
99wrangler4x4
nope. same gear ratio. that equation helped alot!
