#1 | |
2 sets of wheels 2 jeeps
Here is the scenario.
I have one TJ with a 2 in BB and 1.25 bl A stock xj. Both 2000 One set of 4 Ecco rims and one set of 5 canyon rims. I'm totally stoked that I was looking for one Ecco to replace my lost spare rim and came across 5 canyons on CL for free. Which jeep gets which rim? ![]() The canyons look bigger, wider at least. And the TJ is due for, and budgeted for new meats What would you do and why? I do appreciate the feedback, Thanks in advance ![]()
2000 Wrangler & XJ |
#2 |
you can check the tj ones here http://www.jeepforum.com/forum/4121478-post10.html
or http://www.jeepforum.com/forum/4131908-post11.html or search the tj forum part and there is a sticky for stock specs with all the info... as for the cherokee just look under their threads |
#3 |
I guess what I'm saying is that I want to change it up. I already have the standard se rims on the cherokee.
The eccos are on the Wrangler, the canyons are IN the wrangler. I was hoping to ditch the SE rims and go with the eccos on the cherokee, Would you do this as well?
#4 |
The eccos are 15x7 and the canyons are a 15x8 so the canyons would probably be the best on the Wrangler because they are wider.
98 Sport TJ 4.0L [COLOR=darkred]Chile Pepper Red[/COLOR] with Black Dual Tops Trueflow Air Filter 31" BFG A/T Cibies headlamps, plus 30 bulbs other than that pretty much stock for now |
#5 |
Eccos on the XJ and Canyons on the TJ. you can put bigger tires on the Canyons (you'll need spacers for anything over 10.50" wide)
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#6 |
Canyons on the TJ, my only reason being...you have 5 of those and a matching spare seems more appropriate on that.
#7 |
Thank you all
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
