2" receiver tire carrier - JeepForum.com
post #1 of 14 Old 12-22-2005, 03:43 PM Thread Starter
Runnerboy
Have you fellas ever seen anybody use a 2" reciever spare tire carrier? I know a drawback of this would be not having access to the tailgate but thats no a big deal. Would it look hideous if I were to take a a 2" hitch and put a peace of 2" tube going straight up on it and fab a mounting plate for the wheel? Workin in a machine shop it shouldnt be hard to come up with something. That away I wouldnt have to worry about a whole new carrier and could still have access to my hitch if need be. Ofcourse departure angle wont be great..but for a pavement pounder who cares? But then again it might just be a stupid idea...
Runnerboy is offline
post #2 of 14 Old 12-22-2005, 03:56 PM
TXST8tj
TXST8tj's Avatar
not a terrible idea really, but it has plenty of downsides, most of which you mentioned. i think the main key here would be to keep it mounted as close to the body as possible. they do sell these and yes i have seen them on a wide range of vehicles. if you went offroad, you would pretty much need to take it off because it would cause more trouble than it's worth; however, when you do that, you loose your spare tire which is obviously a no-no, so really it comes down to you.
Patrick
TXST8tj is offline
post #3 of 14 Old 12-22-2005, 04:38 PM Thread Starter
Runnerboy
But say if I where doing 4-wheeling..the rear seat will be out anyhow, couldnt I just take it off and set it inside? Its not like Im going to be rolling over or anything so it wouldnt be any danger in a loose tire laying inside.
I have seen them sold at autozone for around $85, thats just for the carrier, it doesnt have a place for a ball on it. Does modifying a reciever sound like a good idea? I might go as far as making some sort of quick discount system for it so I could just pull 1 pin and lift the tire off and have quick access to the tailgate. I guess the biggest problem will be how much its going to wobble around. 2" hitches usually have some play in them..
post #4 of 14 Old 12-30-2005, 03:59 PM
jmanimal
jmanimal's Avatar
I have a bike rack for a 2" receiver that is really close to what you are describing. It has a hinge where the vertical meets the horizontal (into the receiver) and a removable clevis pin. It hinges straight down so you can open the gate. Hard to describe, but where the vertical meets the horizontal, there are triangular plates on each side. The plates are only welded to either the vert or horiz. and use the pin to attach to the other. Couldn't be that hard to make. Ill try to find a pic..
Now:2011 JKU
Gone:2001 TJ;1998 5.9 ZJ;1995 5.2 ZJ
matanzasjeepclub.com
jmanimal is offline
post #5 of 14 Old 12-30-2005, 04:05 PM Thread Starter
Runnerboy
jmanimal I would really appreciate a picture when you get a chance. I think I understand what your saying but it would still be nice to be able to get some design ideas
post #6 of 14 Old 12-30-2005, 09:14 PM
smokeybear
The wobble/rattle problem is easy to fix. Drill and tap a hole in the bottom of the reciever on the opposite end of the pin from the tire carrier (or trailer ball or whatever). Run a bolt - maybe half inch or so - up there solid against the stinger. It will prevent rattling.
02 TJ Sahara 4.0 5 spd, 3.73, Dana 44 rear, 2.5" lift w/ Bilstein shocks, 33x12.50
smokeybear is offline
post #7 of 14 Old 01-01-2006, 01:55 PM
jmanimal
jmanimal's Avatar
Here you go. The longish extended part on the bottom rear is meant to hold a baby receiver (class 2?) If I were to use something like this offroad, I would not include that length.
Now:2011 JKU
jmanimal is offline
post #8 of 14 Old 01-01-2006, 02:03 PM Thread Starter
Runnerboy
Thanks for the pic..it makes perfect sense really! I guess I can start gathering materials at work tommorow! Thanks
post #9 of 14 Old 01-01-2006, 03:44 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One thing to keep in mind is the tremendous amount of leverage a spare tire is going to have over the supporting structure you're going to make. It's going to take some heavy thickwall square tubing, a strong design, and a welder who knows what he's doing.
Gone on vacation until August 25.
Jerry Bransford is offline
post #10 of 14 Old 01-01-2006, 05:35 PM Thread Starter
Runnerboy
I figured I would use 2x2x.25 for the upright piece along with 1/2 plate steel for the triangled hinge section with grade 8 bolts backed with washers on both sides..should that do? Plus I figure if I stick it in with some nice bevels on the edges rather than mig then I should get good deep penatration. What you think? Plus all this shouldnt effect the hitch since the most I will haul is a 600lb 4-wheeler..
post #11 of 14 Old 01-01-2006, 05:44 PM
numchuck
pirate squirrel
numchuck's Avatar
since you are good at fabrication, you should find someone with a "real" swing-away, that you like, and reverse-engineer that carrier . . . (see Jerry's motto, above) . . .
- Chuck -
the "Dude" abides
numchuck is offline
post #12 of 14 Old 01-18-2006, 07:44 PM Thread Starter
Runnerboy
I need some math help. Ive figured up my demensions before when making 4-wheeler spacers on a cnc machine but Im having trouble with the jeep bolt pattern because it is 5 lug instead of 4 like the 4-wheeler. I need to know how far the bolt holes are apart (like a cordinate) ie (2.4,3.5) from a common center point...anyone who can help me with this I could greatly appreciate it. The reason I want it to be so precise is because I will be doing it on a milling maching at work tommorow and I want everything to have a good fit...
post #13 of 14 Old 01-18-2006, 07:48 PM Thread Starter
Runnerboy
on second thought..does the bolt pattern 5x4.5 mean that it is 4.5" from each stud diagonally or does it mean that they pattern is 4.5" on diameter?
post #14 of 14 Old 01-19-2006, 08:55 AM
fr3db3ar
fr3db3ar's Avatar
5 on 4.5 means a diagonal measure if you skip a stud on each side of the stud you are measureing from..... IE starting with any stud as #1......4.5 to #3 and #4
#2 to #4 and #5
#3 to #5 and #1
#4 to #1 and #2
#5 to #2 and #3
98 5.9 Some stuff attached
It's true that I'm old enough to probably have been there and done that....it doesn't make me an expert....it gives me an educated opinion.
fr3db3ar is offline
Fold "down" spare tire carrier Floridazed Fabrication Shop 37 03-27-2011 07:51 PM
Body Armor 54" Rear Bumper w/ Swing Away Tire Carrier - weight? VanBCguy General Jeep & Off-Road Equipment 1 07-20-2009 09:12 AM
You can safely fit a 33" tire on the stock tire carrier on door CB3 Tires & Wheels 35 04-27-2008 01:46 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Difference between LoD extreme duty tire carrier/Heavy Duty tire carrier djaychris General Jeep & Off-Road Equipment 7 12-18-2005 09:53 AM
