Quantcast 2 inch coil spacer how big of tires - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 2 inch coil spacer how big of tires
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 02-21-2010, 11:23 PM   #1
ugobroncs3343
I have a 98 tj wrangler and want to know how big of tires i can put on with a 2 inch coil spacer i would like to put 33 inch but dont know if they will rub i would also like wide tires so they look mean going down the road thank you
if anyone has picture of there tires and lift it would help thanks
ugobroncs3343 is offline   Reply With Quote
Old 02-22-2010, 12:35 AM   #2
ClimbStuff
33's, no lift, no rubbing.
ClimbStuff is offline   Reply With Quote
Old 02-22-2010, 10:20 AM   #3
ugobroncs3343
would i be able to keep my fender flare or did you just decide to take them off?
Old 02-22-2010, 10:23 AM   #4
Imped
TITS
Imped's Avatar
Bumpstops dude, bumpstops.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 02-22-2010, 12:08 PM   #5
03silversport
A 32" tire is the norm afte installing a 2" coil spacer front and back.
03silversport is offline   Reply With Quote
Old 02-22-2010, 12:23 PM   #6
ClimbStuff
I took them off when I had my 31's... I'm not a big fan of flares. The nice thing is though, with the sway bar connected, and fully stretched out, it STILL doesn't hit the fenders... disconnecting is a whole other story.
After all the comments I've read about 33x12.50's on stock TJ's, I expected to have some serious rubbing... but they fit, and don't rub. Which means one of two things...
1. Everyone else just talks about rubbing w/o actually having tried it.
2. I have a lift and don't know it. My shocks and springs appear to OEM and have the little Chrysler stickers on them so I assume it to be stock.
Either way, you can drive around with 33's w/ flares no problem. If you try to stretch it out a bit, you'll start eating up the flares, but never touch the fenders as long as you stay connected.
Old 02-23-2010, 02:54 AM   #7
RogueSpear2023
JF is my second home.
With proper bumpstops you can run 33s with a 2" BB, 32s are the norm, if you add a 1" body lift though you can run 33s with out a problem. I run short 33s with just a body lift, flat flares, .75" spacers up front and proper bump stops.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Old 02-23-2010, 09:44 PM   #8
CB3
You could do what I did. I ran 33 X 11.5 R16 (285/75R16) tires for a year on a stock Rubi LJ with no rubbing on road, and no rubbing offroad either (though I didn't disconnect).
I did this by changing flares to Warn 7" wide flares. A 7" wide flare (maybe a 6, but for sure a 7") will clear the tires because the flare is wide enough that the outside edge of flare that drops down is not above the tire.
This is (IMO) better than removing flares because it doesn't allow rocks to fly up and hit your paint or other cars, and is a considerate solution to other motorists, and is legal.
In most states it's not legal to remove flares.
Removing flares, or putting on a wider stock type flare (like Warn or Omix Ada), or a tube fender, will increase tire clearance by about 1" to 1.5". That's free lift (free in regard to not raising COG).
I prefer a wider stock type flare because this improves mud and gravel retention within fender (less flying debris) hitting your Jeep and other peoples' cars. The other two options increase flying debris. They all increase tire clearance a lot.
CB3 is offline   Reply With Quote
Old 02-23-2010, 09:50 PM   #9
CB3
With wider flares (like my Warn 7") the tire won't touch the flares even if disconnected and articulating. The wide flares have more clearance than the fenders themselves.
Old 02-24-2010, 01:23 AM   #10
ClimbStuff
Whilst that may be true, I'm not a fan of plastic flares, so 7" wide plastics, are just that much worse IMO.
Keep in mind though, I don't really have to deal with mud here, so a flare isn't really necessary on the trails unless running through shallow standing water at slow speed.. then you get soaked.
Old 02-24-2010, 12:43 PM   #11
LL247
Jeep Addict
LL247's Avatar
I'm running a 2'' BB on my TJ with wider flares and 33's...no issues I can find!
I'd love a nice 4'' lift but it's not in the budget, also 33's are the minimum in my book so it all works nicely.
DISCLAIMER - my TJ is primarily a DD so I don't go offroad too often
2008 JK Unlimited Sahara - Some people drive Jeeps and others are Sheeple going along with the herd.
LL247 is offline   Reply With Quote
Old 02-24-2010, 12:48 PM   #12
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Agreed . Depending on the backspacing of your wheel, you may experience some minor rubbing on your front lower control arms or your rear spring/coil perches. The front LCA rubbing if minor, may be resolve with a washer or 2, on your steering stops.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Old 02-24-2010, 01:03 PM   #13
InfernoGirl
I have 33x12.5's on 15x8 soft 8's with 4" BS. 2" BB. I don't go offroad often. Not much room to flex, but it isn't a problem for me since I don't push it. This is what it looks like....
Dirty Mudder seat covers/Steering column covers/spare tire covers
Like my Dirty Mudder FB fan page here: http://www.facebook.com/pages/Dirty-Mudder/135372306475827?ref=search
01 Jeep Wrangler Sport 4.0L, auto Sienna Mine
07 2D Rubicon Flame Red His
InfernoGirl is offline   Reply With Quote
Old 02-26-2010, 02:40 AM   #14
CB3
My Warn flares are poly and look good. Actually, they look stock to most people (because my tire on 4.5 BS 8" wide rim) sticks out an appropriate amount).
Old 02-26-2010, 02:43 AM   #15
CB3
If you're flare was wide enough, you'd gain 1" of uptravel before tire rubber fender (tire would never rub a wider flare).
Then you could push it more, but you'd still need about 1.5" bumpstop extension, IMO.
Because even though you're tires wouldn't hit a wider flare, they would hit the front fender itself, if you pushed the envelope offroad while disconnected.
Glock Forum
