16X8 or 16X10??? - JeepForum.com
post #1 of 10 Old 12-08-2010, 06:02 AM Thread Starter
goberd
16X8 or 16X10???
Question, I currently have 16x8 Rubicon rims with 285-75-16 KM2s on them, looking to go to a black rim, soft 8 or something, anyone have a pic or advice on whether to go 16x8 again or go 16X10???
goberd is offline
post #2 of 10 Old 12-08-2010, 06:07 AM
Matt L
16 x 8
Matt L is offline
post #3 of 10 Old 12-08-2010, 06:30 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
16x8.
TheBoogieman is offline
post #4 of 10 Old 12-08-2010, 06:32 AM
OneLoud
It is harder to clear taller tires on wider rims then it is on narrower rims...that being said, I like the look of the wide stance and wide tire look that the right tire with a x10 wheel gives you.
OneLoud is offline
post #5 of 10 Old 12-08-2010, 06:35 AM Thread Starter
goberd
I have a 4" lift and also have 1.25" spacers if I needed them so I dont think i will have any clearance problems anywhere, I like the wide look of a 10" rim I think
goberd is offline
post #6 of 10 Old 12-08-2010, 06:53 AM
TheBoogieman
Disturbed
Huh.
post #7 of 10 Old 12-08-2010, 06:58 AM
TheBoogieman
Disturbed
If you get new wheels with 4" or less backspacing,you don't need the spacers.
8" wide wheels with 3.75" backspacing.
Same wheels in 10" wide.
post #8 of 10 Old 12-08-2010, 07:15 AM Thread Starter
goberd
rim
Which rim is that?? that is exactly what I'm looking for.
goberd is offline
post #9 of 10 Old 12-08-2010, 07:26 AM
TheBoogieman
Disturbed
Cragar #352 streetlocks.A lot of companies make similar ones too.
post #10 of 10 Old 12-08-2010, 05:40 PM
OneLoud
Huh.
If you are trying to clear as tall a tire as possible without rubbing, a narrower rim will clear a tire easier than a wider one...turn your steering wheel all the way to the right, now go look at the front passenger tire, if you have a wider rim it will it will throw the tire more into the flare/fender because it is hanging farther off of the axle.
OneLoud is offline
16x8 or 16x10? drowe303 JK Wrangler Technical Forum 0 04-11-2010 10:08 PM
what backspacing do I need to run 16x8 TJRoberto TJ Wrangler Technical Forum 3 08-31-2009 12:04 PM
Which wheel? 16x8 or 16x10 MDC3 JK Wrangler Technical Forum 12 08-18-2009 09:21 AM
16x8 Wheels ? KoKid28 TJ Wrangler Technical Forum 4 07-30-2008 04:06 PM
15x10 or 16x10 Beadlocks...? delucsal TJ Wrangler Technical Forum 14 09-05-2004 02:17 PM
