16x7 vs 16x8 - JeepForum.com
post #1 of 10 Old 01-12-2014, 09:00 PM Thread Starter
ThatGuy57
2003 WJ
16x7 vs 16x8
Currently have stock wj. Got new 225/75 r 16 bfg at's on it. I'd like a wider stance and i'd like a set of D windows or soft 8's. All i'm finding is 16x8 with 5 inch backspace or 16x7 with 4 inch backspace. Which would work better? Couldn't really find the answer with the search function and I only got one answer on the wj forum but it wasn't any help. Any help would be appreciated.
If it ain't broke, it will be by the end of the day.
Past jeep- 98 white cherokee, 3" zone lift, 31x10.50 general grabber at2's, bds steering stabilizer, 15x7 soft 8's with 4" bs~R.I.P
ThatGuy57 is offline
post #2 of 10 Old 01-14-2014, 04:47 PM Thread Starter
ThatGuy57
2003 WJ
Nobody has any idea?
post #3 of 10 Old 01-14-2014, 06:36 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Both of those wheels will put the outer edge of the wheel/tire combo in the same location.
Go with the 7" wheel. Its a better match for the 225mm width.
Wheelin98TJ is offline
post #4 of 10 Old 01-15-2014, 04:36 PM Thread Starter
ThatGuy57
2003 WJ
Awesome, thanks. Any rubbing to be expected?
post #5 of 10 Old 01-15-2014, 05:51 PM
Wheelin98TJ
JEEP FREAK
I'm not sure, you might want to ask over in the WJ Forum.
post #6 of 10 Old 04-07-2015, 10:18 PM
BigPhil722
what about 265/75/16 tires with a 4 inch lift? 16x8 or 16x7?
BigPhil722 is offline
post #7 of 10 Old 04-14-2015, 02:31 PM
Millermagic
Depends on how wide you want to go in the future.
If you already have 16x7 - they will work. 16x8 should also work. Have a 2001 Ford truck that came with 265/75-16 on 16x7 wheels and it works fine.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #8 of 10 Old 04-14-2015, 07:22 PM
Bigmac84
I run 265/70r16 on a WJ with 2.5" lift. Only rubs a tiny bit at full lock in reverse. They are mounted in the original 16x7 Timberline rims and are perfect.
Bigmac84 is offline
post #9 of 10 Old 04-20-2015, 12:53 PM
Charley3
Agreed
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #10 of 10 Old 04-20-2015, 12:55 PM
Charley3
I don't know, but in general, wider stance means tires are more likely to contact flares.
Charley3 is offline
