16" E load range tires on CJ7 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 16" E load range tires on CJ7
Poison Spyder from CCOR!REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 07-01-2012, 06:22 PM   #1
aggiejon
1979 CJ7
Wanted to see if anyone has used any E load range tires on a jeep? Been thinking about putting my 285/75r16 tires off my truck onto my jeep. Would have a place to go with my still ok tires and have some interchangeability.
aggiejon is offline   Reply With Quote
Unread 07-01-2012, 07:12 PM   #2
Millermagic
I use load range E tires on my Cherokee. They do make it ride like a lumber wagon and I feel almost every bump in the road. I have them at 30psi and that's as "hard" as i feel comfortable.
For fun once, I inflated them to the full 80psi and tried to drive. It definitely bounced off of the road on bumps.
At 26-30PSi they aren't terrible.
2000 XJ - ProComp 3.5'' rear leaves, 3.5'' front coils, JK Shocks, TreadWright LT215/85r16 Crawler MT-E and some tow hooks. Skid plates in the garage.
Millermagic is offline   Reply With Quote
Unread 07-01-2012, 07:15 PM   #3
aggiejon
1979 CJ7
I figured they would ride rough. But also figure the extra ply's would improve its ability to avoid flat tires.
Unread 07-02-2012, 08:49 PM   #4
Millermagic
For what its worth, I can run mine with 0 psi and they just look a little soft.
Unread 07-04-2012, 10:55 AM   #5
castorriver
Why don't you check out Goodyear MT/R's with kevlar instead? Then you'll have more puncture resistance with a lighter load rating.
Registered Nurse Jeep Club Member #1 (I think...
Winter is coming.
castorriver is offline   Reply With Quote
Unread 07-04-2012, 11:11 AM   #6
aggiejon
1979 CJ7
Because I want to be able to run 285/75r16 e range tires that I run on my truck (as mentioned in my initial post).
I also don't want to spend big money for tires on my jeep. Functional gets it done for me.
Unread 07-04-2012, 11:12 AM   #7
aggiejon
1979 CJ7
So basically could be "run flats"! Haha, awesome!
