15x8s or 15x10s?? - Page 3 - JeepForum.com
post #31 of 42 Old 12-03-2010, 04:59 PM
NoStreetJeep
i run a 36x12.50-15 tire on a 15x10" rim and run 10psi in them always.....i wish i had a wider tire. they look too skinny and its not a wide enough foot print for wheelin' on a tire that tall...in my opinion.
it all depends on your setup, your tires and if its a daily driver or you actually use it.
i don't really like the look of a 33" on a 10" wide wheel though....so anything over that i would recommend a 10" wide wheel.
NoStreetJeep is offline
post #32 of 42 Old 12-04-2010, 11:03 AM
yj94sahara
Originally Posted by JeeperDon View Post
. It usually takes more years on the planet to realize you don't know everything. Oh, and use the shift key more often please.
trust me guy, i know i dont know everything, i might have came off a little arrogant about the macys thing so thats my bad
fast and hard... the only way i know how!
Originally Posted by YJFreak:
"Seat belts work, engine runs, tires ain't flat. What more do you want?"
yj94sahara is offline
post #33 of 42 Old 12-05-2010, 10:12 AM
Butterbuddha
2010 JK Wrangler
I just put 15X10's and 35s on my Jeep. (First Jeep, first time EVER changing wheels or tire size) So being the resident ******* I went to Goodyear's page and they recommended no smaller than 8.5" and no greater than 11" wheels for my MTRs. Funny thing is, the sand guys pick on not having 8", and the hotrod guys pick on not having 12". So if nobody thinks I'm a genius, I must be doing something right
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #34 of 42 Old 12-05-2010, 12:10 PM
lckdrgn
Please don't flame:
I'm running 30" on 15x7. After lift going to run DuraTrax 33x12.5. One posted stated these run alittle narrow.
? Could these run on 7" rims safely? DD and towed behind RV. Was looking to buy 5 more rims and get 8's.
Thanks
lckdrgn is offline
post #35 of 42 Old 12-05-2010, 12:27 PM
Gary2
most 1250s usually say 8.5" so I feel the regular 8" most of us use are already pushing it
Gary2 is offline
post #36 of 42 Old 12-05-2010, 01:36 PM
2005X
pushing what?
2005X is offline
post #37 of 42 Old 12-05-2010, 04:11 PM
Mark5
35s on 15x8 here. i run em about 10psi with no broblems
Mark5 is offline
post #38 of 42 Old 12-05-2010, 05:25 PM
Gary2
Originally Posted by 2005X View Post
pushing what?
Pushing the limit beyond the manufacturer's recomendations is what I mean when I say "pushing it" . Some tire places won't mount the combination you are asking about . look around the forum and see what the rest are doing . Most any tire we use can be mounted on an 8-10" .
Gary2 is offline
post #39 of 42 Old 12-05-2010, 06:36 PM
DarksideMspts
....I also run a 12.50, on a 10" wheel....and haven't had any problems yet...but, I'm new at this....so I guess time will tell, huh? I think it looks tougher, and seems to work pretty well, for me.....so far.
'89 Jeep YJ, 4.2/5 speed, SOA lift, TAG TJ pocket flares, HI-LIFT, longer shocks, longer brake lines, 15x10's w/ 33x12.50x15 coursers, pretty cool dude drivin'....and a lot more in store....
DarksideMspts is offline
post #40 of 42 Old 12-05-2010, 06:43 PM
2005X
those same tire manufactur's will also say never air down, dont offroad blah blah to cover their ***. it is well known that the "8 is perfect for a 12.5 tire
2005X is offline
post #41 of 42 Old 12-05-2010, 09:10 PM
KKiowaTJ
The only thing that could be considered "pushing" it is that a tire can fold over on itself in a turn. But it dont apply to us for the fact you need speed, Graduated corner and 10psi in your tires on the road. Thats too many factors for a "might". If you do fall under those you shouldn't be in a jeep.
When i say speed, Thats 75+mph. Jeeps are not sports cars or even a SUV to chance at high speeds or turning with much force.
All manufactures recommend 8.5-11" wheel. But thats for street use no matter if its a a/t or m/t. But you also have to factor that all tires but SS come under sized and not a true 12.50 width. So with a under sized tire I'm pretty sure the .5 difference is IMO not a factor. As mentioned its to cover their ***. If you read the fine print off road to them is a gravel road and a pasture.
Either way it comes down to preference and what kind of wheeling you do and how much time you jeep is spent on road.
MOPAR!
KKiowaTJ is offline
post #42 of 42 Old 12-06-2010, 04:52 AM
Gary2
I guess you could also just look at the Jeeps in the forum, signatures, profiles and see who is running what and then you know you are not getting " Do as I say not as I do" .
Gary2 is offline
Advantage of 15x10s? BigGillyStyle Tires & Wheels 16 11-22-2007 07:12 PM
10.5 wide tires with 15x10s redcj576 Tires & Wheels 5 10-25-2005 06:12 PM
is it possible to run 15X10s on a stock TJ TQ_xvi Tires & Wheels 1 06-13-2005 12:32 AM
upgrade to 15x10s?? jackal Tires & Wheels 6 08-16-2003 04:26 PM
32x11.50 on 15x10s? Slim Tires & Wheels 3 10-14-2002 08:46 PM
