15x8s or 15x10s?? - JeepForum.com
post #1 of 42 Old 06-16-2010, 06:46 PM Thread Starter
rwilhite07
15x8s or 15x10s??
ive always ran no smaller than a 10'' wide rim but ive always had trucks ( 3 tacomas and 2 f-150s ) just got my first jeeps and its on chrome 15x10s and i hate chrome. looking at prices and 15x8s are much cheaper and also looking around on here looks like most people run 15x8 on there jeeps.. what do you guys prefer?
rwilhite07 is offline
post #2 of 42 Old 06-16-2010, 07:05 PM
misfitXJ_97
1997 XJ Cherokee
I have 15x10s on my 97 xj with 33x12.50 tires, I like the look and never had issues with them off road,but I never aired down the swampers.
My 03 tj has 15x8s with 35x12.50 tires and I don't like the look but I found out that they hold the bead tighter so if you are airing your tires down to go wheelin they are better.
misfitXJ_97 is offline
post #3 of 42 Old 06-16-2010, 07:09 PM Thread Starter
rwilhite07
alright thanks..
post #4 of 42 Old 06-16-2010, 11:21 PM
RogueSpear2023
The 15x8 are really optimal for a 12.5" wide tire, very good at holding a bead when aired down, while still providing great on road manners, also 15x8" will reduce you chance of destroying a wheel off road. So basically if you run a 12.5" wide tire you want 15x8". if you run a 13"+ wide tire you need 10" wide wheels.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #5 of 42 Old 06-16-2010, 11:22 PM
SOLIDJP44
15x8 on a 12.5 wide tire
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #6 of 42 Old 06-17-2010, 04:55 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
x12.15 tires on a x10 wheel is for posers.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 42 Old 06-17-2010, 07:30 AM
Ross
I have ran both, 8's and 10's. You can air down lower, not much and really not much of an issue for most. If it is I would recommend you run bead locks.
With 10 inch rims you can run on road at a higher PSI. This should give you longer tread life and possibly better gas mileage. The down side to tens is you can tear them up on the trails. They aren't as protected by the tire and will take a beating. Mine where so torn up I had no choice but to get rid of them. They leaked slowly, one was so damaged that I don't think I could ever mount another tire on it again, the others leaked. Another issue with the 10s was I seemed to get more crap in my bead than with my 8's. Plus 8s will tuck into you fender better and won't stick your tires out as much. You can get them with more back spacing which helps to keep them under the jeep better and rubbing less at full flex.
I am happier with 8s.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #8 of 42 Old 06-17-2010, 07:38 AM
03silversport
15x8
03silversport is offline
post #9 of 42 Old 06-20-2010, 03:58 PM
CB3
There are some good 15 X 9 wheels available today. They were very rare and hard to impossible to find for a few years.
But have recently become a bit more common again.
Trailready and Mamba make them, and also another brand or two whose names I can't think of. Mamba makes a nice variety of BS to choose from.
CB3 is offline
post #10 of 42 Old 06-20-2010, 04:00 PM
CB3
I agree with everything you said, but want to add one more thing:
A 10" wide rim giving flatter footprint at street pressures helps tire last longer (as you said), and maybe improves highway gas mileage (as you said), and the flatter footprint helps winter road traction, and is especially effective at reducing side slipping because a flatter footprint at street pressure means outer edges of outer tread lugs contact the road at steet pressures.
I prefer a 15 X 9 for a 12.5 wide R15 tire because I think it offers the best of both worlds. <== That's if a guy wants a 12.5 wide tire.
I'm currently running 15 X 8 with 33 X 10.5 tires and am happy with that, but if I wanted a 12.5 wide tire, then I'd prefer a 15 X 9 wheel.
CB3 is offline
post #11 of 42 Old 06-20-2010, 06:09 PM
flatlander757
I run 40x16 tires on a 17x9.5" beadlock. Works great, no problems. FWIW my tires do actually measure 14" wide though, no way you can get 16" from them.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #12 of 42 Old 11-30-2010, 09:50 PM
misfitXJ_97
1997 XJ Cherokee
Just read this forum again and I really dislike the guy that said 12.50s on 15x10s are for posers. Not true I have ran 12.50s on a 15x10 with no issue for quite a few years now and never blew a bead, had issues with rubbing the side of the rim on anything on the trail, or any issue with that rim/tire setup on anything from minor rocks to heavily wooded trails. There is a practical way to build a jeep and there is the way you want to build you jeep, i say do it the way you like and make it work and prove the naysayers wrong.
post #13 of 42 Old 12-01-2010, 07:59 AM
Ross
I ran 10 inch for a while. I could run them down to about 10pis before I lost air off-roading, never broke a bead.
After a few years my rims where so beat that A couple would lose about 10lbs of air within a few days. One of the rims was so beat i don't think that new tires could have been mounted. I would rip off another wheel weights every time I wheeled (I use BBs now to balance). I had aluminum rims and did rock crawling when I had the rims.
I have 8" steel wheels and I did dent the bead on one of them also but steel can be beat back and even with the dent they have take less abuse the wider 10" rims.
I wouldn't say that 10" rims are for poser but I wouldn't run them again.
Ross is offline
post #14 of 42 Old 12-01-2010, 09:24 AM
JeeperDon
JeeperDon's Avatar
Originally Posted by rwilhite07 View Post
... looking around on here looks like most people run 15x8 on there jeeps.. what do you guys prefer?
Is that a trick question? Do you think those 'most people' would run what they didn't prefer? I always figure for off-roading and airing up/down, "tire = 1.5 x wheel" is a good rule of thumb. So 12.5 tires on 8's, etc. I actually run 12.5's on x7 wheels, for many years.
Web Admin for
post #15 of 42 Old 12-01-2010, 10:22 AM
YJames90
YJames90's Avatar
12.5 on 7s here. I air down to 10 with no problems
YJames90 is offline
Advantage of 15x10s? BigGillyStyle Tires & Wheels 16 11-22-2007 07:12 PM
10.5 wide tires with 15x10s redcj576 Tires & Wheels 5 10-25-2005 06:12 PM
is it possible to run 15X10s on a stock TJ TQ_xvi Tires & Wheels 1 06-13-2005 12:32 AM
upgrade to 15x10s?? jackal Tires & Wheels 6 08-16-2003 04:26 PM
32x11.50 on 15x10s? Slim Tires & Wheels 3 10-14-2002 08:46 PM
