15x10 / 15x8 differences? - Page 2 - JeepForum.com
post #16 of 23 Old 01-28-2014, 04:05 PM
tjkj2002
2002 KJ Liberty
Originally Posted by 3X4X4 View Post
If you read the manufacturer specifications the minimum wheel width for a 12.5 inch tire is an 8.5 inch rim. I realize that it is common practice to run them on an 8 inch rim primarily for trail use.
over 3 years and 20,000 miles and no issues with 12.50's on a 8" rim,no funny wear at all since I keep my Jeep in alignment.
Originally Posted by biffgnar View Post
No reason 12.5" on an 8" have to be primarily for trail use. They work just fine on the road.
X2......................
tjkj2002 is offline
post #17 of 23 Old 01-28-2014, 07:19 PM
3X4X4
I am not arguing what you do anecdotally, only factually what most tire manufacturers state, minimum rim width for a 12.5 inch wide tire is 8.5 inches.
Like I said, I realize the 8 inch rims are a common fitment with 12.5 inch wide tires on Jeeps. I am torn myself with this very question. My Jeep is a DD and I do not "wheel" but I do go significantly off road to explore on occasion.
J
3X4X4 is offline
post #18 of 23 Old 01-28-2014, 07:30 PM
tjkj2002
2002 KJ Liberty
J
Well if you measure most 8" rims they mostly measure closer to 8.5" anyways.
tjkj2002 is offline
post #19 of 23 Old 01-29-2014, 09:09 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Not saying I'd follow their recommendation, but when a tire manufacturer recommends a wheel width, I'd have to imagine it's based on the conventional method of measuring wheel width.
Wheelin98TJ is offline
post #20 of 23 Old 01-29-2014, 09:58 PM
tjkj2002
2002 KJ Liberty
Well I wish they could learn how to make tires the correct sizes,like what is stamped on the sidewall.
tjkj2002 is offline
post #21 of 23 Old 02-03-2014, 02:34 PM
gsaxe
apparenlty lumber mills and tire makers have something in common
AKA Catfish
gsaxe is offline
post #22 of 23 Old 02-03-2014, 02:52 PM
Ross
Another issue I had with 10 in rims was always getting crap stuck in the bead and loosing air. There were times when I had to have the ties remounted to get the bead cleaned out. I havenít had this issue since I switched to 8 inch rims.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #23 of 23 Old 02-04-2014, 06:53 PM
Gary2
For a 12.50 I have always preferred the 8" wheel so I could run a little less air on the street to have a better ride and not be wearing the outside edges like it would if it was mounted on a 10" wide wheel . Also a 12.50 tire is not a big enough tire to justify sticking way outside the fenders as they do on a 10" wheel . It just makes it look like a poor choice of wheels for the most part . a 12.50 will protect an 8" wheel more than it will a 10" . 10 is ok if you are running something like a 14.50 then you have a big tire on a big wheel , a better match .
Gary2 is offline
15x8 or 15x10 Fred007 YJ Wrangler Technical Forum 12 05-23-2008 08:10 PM
15x10 or 15x8 ronandunf YJ Wrangler Technical Forum 15 03-29-2007 09:02 AM
15x8 to 15x10 jeepboy21 YJ Wrangler Technical Forum 2 02-06-2007 04:21 PM
15X8 or 15X10? mcoughlin YJ Wrangler Technical Forum 11 11-22-2006 08:41 AM
15x8 or 15x10 SEZARO21 YJ Wrangler Technical Forum 16 10-04-2006 10:39 AM
