15" Rims on JK - JeepForum.com
post #1 of 4 Old 09-04-2013, 03:18 PM Thread Starter
cjohnson2209
1980 CJ7
15" Rims on JK
I have a set of new 33" tires currently on steel 15" rims (5x5.5 intended for my CJ7). I want to swap the tires over to 15" rims that will fit my new JK (5x5). I've been told I will need to grind on the calipers in order to fit any 15" wheel.
I will be lifting the jeep JK and adding spacers. Will the spacers alleviate the rubbing issue?
Suggestions? Thoughts?
Thanks for the help.
cjohnson2209 is offline
post #2 of 4 Old 09-04-2013, 09:42 PM
brokenyoujoint
that would be a lot of grinding on the calipers.. I wouldnt recommend it...
brokenyoujoint is offline
post #3 of 4 Old 09-05-2013, 06:35 AM
egodfrey
egodfrey's Avatar
I have heard that most 15" wheels fit right onto a jk
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #4 of 4 Old 09-08-2013, 04:04 PM
nocojeep
1990 XJ Cherokee
Many companies are now making wheels that are 15 x 8 with negative offset or low backspacing that will not require any caliper grinding because they move the whole assembly farther out and will not cause any rubbing, look on this page... http://www.discounttiredirect.com/di...rue&wd=15&rw=8
nocojeep is offline
2007 unlimited , caliper , rim size , tire fitment , wheels
