The BL lifts the body off the frame 1 inch mainly to give room for larger tires. The MML lifts the motor 1 inch and is normally used as an alternative to the cheaper TC drop or the more expensive SYE option to correct drive lines.
The BB actually lifts the suspension and at 2 inches should give double the clearance for larger tires.
1" BL will give you nothing but tire clearance....
1" MML only gets you 1" of oil pan clearance and helps with vibes if you had any...
I prefer to install both a 1" MML and a 1" BL at the same time...whether it's on a 2" BB or a 3.5" full lift...
Greg
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
