1" MML a substitute for 1" TC drop? - JeepForum.com
post #1 of 2 Old 04-28-2004, 08:54 PM Thread Starter
BigWaylon
tubework is cool...
BigWaylon's Avatar
OK...did a search for MML* (only came back with 25 responses, which I found odd)...but found conflicting data, so I'll ask it again...
I installed the 1" TC drop that came with my lift...
To regain clearance, can I install a 1" MML, and remove the TC drop? In reading, it appears I "might" need to put just a couple washers in as a drop instead of the 1" spacers?
To piggyback with that...can I do just the MML? or do I have to do a 1" BL as well...
I know the BL/MML combo allows me to skip all the radiator shroud issues...but, are there any other issues to consider?
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #2 of 2 Old 04-28-2004, 10:14 PM
igofshn
Locked @ both ends
igofshn's Avatar
It isn't the same. It will help with vibes but it might not get rid of all of the vibes.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
Looking to drop a 6cyl into my 98 "HELP" thanks tylertj Engines & Drivetrain 1 11-20-2009 04:50 PM
Quadratec "At Drop Shipper" TheDustMan General Jeep & Off-Road Equipment 4 08-04-2009 01:09 PM
98 Tj, 2" BB lift, 2" Wheel Spacers, 1" TC drop, still vibrations Wittman Engines & Drivetrain 13 02-10-2009 12:57 PM
1" MML & 1" Tcase Drop mike_dippert Engines & Drivetrain 5 03-08-2008 08:49 PM
Does 2" OME lift + 1" Body/MM lift = No TCase Drop? Black 2001 TJ Tires & Wheels 4 10-24-2002 07:57 AM
